GLC63 Engine Replacement
My question is has anyone had this issue? Has anyone had to have one of their 63's engine replaced?
Are there any options besides replacing the engine? I am not sure how I feel about having a replacement engine in our 8 month old vehicle with only have 2300 miles on it.
Just looking for anyone with experience with this type of situation
It won't help resale values either to have a non-original engine.
I personally would try to get a second opinion from a respected independent mechanic. It could be the dealership making work to soak the Mercedes warranty. As a Jaguar and Land Rover owner, there's no doubt that those dealers take advantage of the generous factory warranties.
A car like this, doesn’t need to be “numbers matching” like a 69 Z28, to hold value. They cars are meant to be driven, hard. Most people will go get the latest and greatest in 5-6 years. All manufactures have anomaly’s and have failures, Mercedes has had problems in the past with various systems and have been good about fixing them. From my observation.
The balancers are keyed on the to shaft. If the bolt came off, and the pulley did not fly off, then it stays keyed to the shaft.
I am not like most people here because I actually work on all my cars from Lamborghinis to Lotuses to Jaguars to Range Rovers, so I know not to have blind trust in "professional" mechanics.
https://youtu.be/OHaWqZT0wRo?t=835
But with the little information we have here, a car that is still under warranty, an indy shop we don't know, all odds are against a non dealer solution.
I would say that in this case the owner is better off with the engine change, despite things can go wrong.
If things go wrong at the indy, MB will reject all further claims, and the owner is f...ked.
Is it worth the risk ?
If you are in the US, expect the engine replacement to be on the carfax for all to see. Heck, sometimes if the dealer pumps up the tires, that ends up on the carfax.
Best of luck!
- Negotiate maintenance packages and extended warranty on the car if you are planning to keep the car long-term
- Or as your car is practically new, refuse the engine swap and ask them to take the car back and give your money back as this is pretty unacceptable from Mercedes. Just keep pressing hard on them and either get a new car or a refund.
If MB say the engine needs to be changed then without throwing away your warranty you may just let them at it.
I understand how it feels as I had to have an engine replaced in my VW Touareg a few years ago.
The new engine will have a full warranty from date of fitting.
Tell us, do you make it a habit of making decision without having a clue??
You mentioned "6-8 weeks" replacement time - two things - (1) is the dealership providing you free loaner for this period ? (2) between you-me-other forum members are you familiar with the Lemon Law's in your state ?
MBUSA - and/or your MB dealer - is not going to stand-up and and say "we want to give you a new Mercedes" - but between you and a attorney you should see where things lay about that due to the length of time your rig will be in the shop for completion of the repairs which have been identified as manufacturer defect...
Now ... that part is NOT a conversation for you to have with your Dealer and NOT a conversation between you and MBUSA... the way this starts (if you decide to do it) is a Certified Letter from the attorney to MBUSA which kicks in a whole other process ..
It's your call...
