GLC tire balance - Hub-centric or Lug-centric
The tire shop has not been able to get a good balance on the tires. I have gone back twice after the original mount and balance, and it's still off.
After the latest effort, it is worse, but instead of feeling like a balance issue, it seems like I'm driving on rocks.
Which makes me wonder just how the tire shop is fitting the wheels to their balance machine.
So, This Question:
Should they be mounting the wheels on the balance machine via Hub-Centric, or Lug-Centric attachment?
__________________
I have been out of the tire business long enough that I'm not familiar with the new equipment. I used to look for Hunter 97xx balance machines, which do Road Force balancing, but they are two generations old. I don't know what adapters, or visual aids the new crop of machines provide to eliminate simple "wrong adapter" problems.
@superswiss Do you think a lazy technician might actually use a lug-centric adapter, or wrong cone or spacers?
BTW I think all M-B shops are required to employ Hunter 97xx balancers at the minimum, so Road Force is possible at any M-B shop.
What type of tires did you put on? What shop are you using?
I found, in my years at Firestone and multiple dealerships, that most techs just have no idea how to properly balance a tire. I 'fixed' many balance problems just by balancing the tires properly. Seems simple, but many people working in the industry couldn't fix a sandwich, let alone a complex modern automobile.
