Advice for someone who has just got their first GLC 250D
Old Apr 9, 2021 | 11:35 AM
Aussiechappy's Avatar
W204 C63 2009 and X253 250D 2015
G'day everyone. Just got my wife a 2015 GLC 250D with about 98k on the clock she didn't know we were getting so was almost in tears when I gave her the keys
Only got it licenced today I'm in WA and it came over from NSW so just really being able to drive it today. Very happy with it but some questions I'm hoping someone might be able to help me with.
When pull up at a stop sign or traffic light the engine seems to shudder as I'm just about to stop and then it's fine. I've never had a diesel before, does this seems normal? I tried it in 1st gear and it does the same thing, so I don't think it's transmission related, I'm just not sure if it's just the way they are.
Next, the codes for the car seem to indicate that it has sensor for the boot to open 871 SENSORS FOR TRUNK LID OPENING/CLOSING but for the life of me I cant seem to get it to work? Any tips please?
Finally we have the head up display, but it doesn't indicate traffic speed signs, the videos I've watched seem to show this, is it something to do with the maps or do the cameras read the signs?
The car has a 2 year MB warranty, anything in particular I should be mindful of?
I'm sure I'll have more, thanks in advance, appreciate the advice, cheers.
Old Apr 10, 2021 | 03:12 AM
Teckno's Avatar
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
Firstly Big Congratulations.
Not sure re shudder when about to stop, could be several factors, is drive select in Comfort or in Sports or Sports + ? Car behaves very differently in those last settings.
Could also be stop start kicking in and out, can vary depending on brake pressure on pedal, but usually a only when stopped. See how that goes.
Not knowing history of car and if it was a short tripper or a longer drive one there may be some build up odd deposits in injectors. Buy a bottle of heavy duty Nulon diesel fuel system cleaner and then fill with good diesel, like BP Vortex, 2 cents dearer than truck diesel.
2 or 3 tanks of fuel later I would do the same, that is fill fuel tank with Nulon DPF cleaner and run that, do not mix with fuel injector cleaner.
Another issue, minor though is the cars battery could be low on charge, depends on storage, travel, etc. Buy a Ctek 5.0 battery charger around $99 on special at Repco and put battery on charge for 24 hours, use AGM setting on battery to charge it at correct rate. Positive terminal passenger side under red slide and negative terminal on passenger side , copper round nit towards front headlight.
Check TYRE pressures when cold are at around 36-38psi, even though fuel lid says 32psi. Better TYRE wear and handling.
Check what tyres fitted, run flat simmer ? Or run flat all season M&S, like Goodyear Eagles.
Ask Dealer if car has had front steering knuckles replaced, not a recall in Oz, but hundreds done and thousands done in RHD in UK. Get it done under warranty ($4000 if you pay).
Boot opening sensor a bit hit and miss, do you have tow bar fitted ?
Heads up works fine, Aussie ADR design has it traffic sign data disabled in Oz as no common design type across nation. None of ours have it - few feature in Oz are disabled.
Ask for a printed history of service , can generate one at dealer for all services.
Check if 5 year auto and transmission service undertaken, this is around $1500-$2000 - if not it needs to be done, Dealer should have done it as part of factory guidance. Brake fluid every 2 years, Panna sunroof service every 3 years ?
get a reading of front and rear disc wear, can be soft and adaptive cruise can wear brakes out sooner, but great feature I am happy to pay for brake usage.
This is a good Aussie site too - https://forums.whirlpool.net.au/thread/9xw76563?p=246
Best of luck, great car.
Happy to PM or talk on mobile / email in future if you have questions.
Old Apr 10, 2021 | 09:06 AM
@Teckno Mate, thanks very much greatly appreciated.
I'll use the heavy duty Nulon diesel fuel system cleaner when next fill is required, only done about 50kms since getting it so far. Then 2 -3 tanks later use the Nulon DPF cleaner, cheers
Will get the charger, this was also a concern of mine as I'm sure it's been sitting in the yard for a while before I got it, then it was a month from purchasing until getting it, it really needs a good run so I'll go for a decent spin during the week hopefully.
Tyres... when it arrived the 2 front tyres (run flats) were completely worn out, one down to the canvas, the dealership has now said they will reimburse me for these 2, I have no run flat tyres, and no spare lol !! (only funny till there is an issue)
Will get the printed service history, the books didn't come with it, even though it was sold to me by a MB dealership, they have sent me a list of the services but it is 1 line saying when they were done and non-descriptive, and will find out about the front steering knuckles, would these be a MB warranty item do you think?, thanks.
It came with a 2 year MB warranty, that gave me reassurance to buy it from the other side of the country without driving it first, however the service assist says A7 service due in 35 days, ( which I think means trans service also right?) They have told me the service has been done and that the mechanic must have not reset it, I'll get confirmation that the A7 service has been completed.
All good about the Heads up, just a shame really, and I'll check with the service centre about the boot opening sensor, there isn't a tow bar.
Thanks again for taking the time to reply and your advice.
Old Apr 10, 2021 | 09:41 AM
Teckno's Avatar
There is a Russian site that if you enter VIN, it will provide a 5 page build state with numbers and descriptors. Alternatively visit your local ask for a data print and it will do same, handy to have.
On MB web site there is an option to download the full owners manual, about 100 pages extra than printed edition. I believe Dealership should have ordered a MB car folder and printed manual, with supporting addendums to be placed in the car for you, via their Spare Parts Dept.
Ask for a print out from selling dealer of latest wheel align settings.
Steering Knuckle issue is a full warranty issue, with free wheel align.
Have car assessed by local Dealer there for them to submit warranty claim to HQ - better to do before new tyres fitted.
When approved, get new tyres, have knuckles changed over and have wheel align done with new tyres and knuckles fitted.
Have your local MB Dealer inspect car to see if auto transmission service done - can tell by new parts under car and service record, they can reset service warning.
Goodyear All Season run flats harder ride but better wear rate. If you want performance , good ride then summer Michelin Latitude 3 are good, but no spare, no foam fill kit. Will need jack, emergency rim kit for around $1000 from Spare Dept, or get second hand TYRE/rim from another model, AMG front brakes and rim may interfere with some non model rims.
The selling dealer should have installed all current Service Level updates for auto, engine ECU, etc. This should be recorded on documents, Your local Dealer might be able to confirm via an OBD11 connection and analysis.
I also put in engine oil at change a 300ml bottle of friction modifier like Liqi Moly, from likes of Super Cheap. Read instructions, the Nulon bottle treats 16l, you only need to treat 6L.
Hope this helps.
Old Apr 10, 2021 | 05:03 PM
Fantastic, thanks @Teckno
Have already got a print of of the print state with numbers and descriptors Have attached below for interest, really missing Command System with Burmeister, memory seats, AMG line (they are the things I wish it had but don't) but still very happy with my purchase
I had to get the front tyres done already as it wouldn't have passed inspection as they were, and I was told there were no run flat's available by my tyre guy, who I've used many times and do trust. They have only been on since Thursday so I'll get to MB Dealer asap to have it assessed re the Steering Knuckle.
Great to hear its a warranty issue, do they often kick back on warranty items, or are they quite agreeable regarding getting them sorted?
When I bought my C63 in for it's first service, bought pre-owned through MB, they hit me up for a list as long as your arm for items, for thousands and thousands worth of issues, and then when I asked about the warranty they seemed dumb founded. It hadn't been lodged correctly, so they had to do most of everything they had said under warranty. I feel they wouldn't have come back to me with so much wrong if they knew it was under warranty. What are your thoughts?
Will also get the info re the transmission service, but also ask the original selling dealer confirm that it has been been as per the service requirements, as they have told me.
I've not ever used any additives like Nulon on any vehicle previously, but from what I've read since you recommended, they really look like the way to go.
Also I have the Audio 20 system (might get an after market android system put in later, any reccomendations?) Does the linguatronic system even actually do anything? Just gives me a language not supported warning, I don't use it in the W204, just interested. And is that NGT 5.0 possibly to upgradable to later version?
Thanks again for sharing your knowledge.
Specs & Equipment
Identification and technical specifications (as received from the manufacturer)
MAKE
Mercedes-Benz
MODEL
GLC
PRODUCTION YEAR
2015
ENGINE
2.1 l
TRANSMISSION TYPE
Automatic
DRIVE TYPE
AWD
ENGINE DESCRIPTION
OM651
DESTINATION MARKET
EUROPE
ENGINE CODE
651921
Equipment (as received from the manufacturer)
CODE
DESCRIPTION
CODE
DESCRIPTION
221
LEFT FRONT SEAT, ELECTRICALLY ADJUSTABLE
222
RIGHT FRONT SEAT, ELECTRICALLY ADJUSTABLE
233
AUTONOMOUS INT. CRUISE CONT. PLUS (DISTRONIC PLUS)
235
ACTIVE PARK ASSIST
237
ACTIVE BLIND SPOT ASSIST
238
ACTIVE LANE KEEPING ASSIST (FAP)
249
INTERIOR AND EXTERIOR MIRROR,AUTOMATICALLY DIMMING
253
REAR-END COLLISION WARNING AND PROTECTION SYSTEM
266
DISTRONIC PLUS CROSS SUPPORT (DTR+Q)
268
EXPANDED BRAKE ASSIST (BAS+)
269
BRAKE ASSIST PLUS CROSS TRAFFIC (BAS+Q)
270
GPS ANTENNA
271
AUTONOMOUS BRAKE INTERVENTION/WARN. FOR PED. PROT.
274
TELEPHONE ANTENNA
293
SIDEBAG IN REAR LEFT AND RIGHT
294
KNEE AIRBAG
299
PRESAFE
300
COLLISION MINIMIZATION BRAKE INTERV./WARNING (CMS)
309
CUP HOLDER
345
RAIN SENSOR
355
PREINSTALLATION FOR NAVIGATION RETROFITTING
357
SD CARD NAVIGATION
413
PANORAMIC SLIDING SUNROOF/GLASS SUNROOF
421
9-SPEED AUTOMATIC TRANSMISSION
448
TOUCHPAD WITH ROTARY PUSHBUTTON
463
FRONT VIEW DISPLAY (HEAD-UP DISPLAY)
474
DIESEL PARTICULATE FILTER
477
TIRE PRESSURE LOSS WARNER
485
(COMFORT RUNNING GEAR)
500
ELECTRIC FOLDING OUTSIDE MIRROR
501
522
AUDIO 20 RADIO NAVIGATION CAPABLE NTG5
537
DIGITAL RADIO STANDARD DAB (DIGI. AUDIO BROADC.)
554
PREINSTALLATION FOR TRAILER HITCH
580
AIR CONDITIONER
611
AMBIENT ILLUMINATION
625
VERSION FOR AUSTRALIA
628
AUTOMATIC HIGH BEAM SWITCH PLUS (IHC+)
641
DYNAMIC LED HEADLAMPS, LEFT-HAND TRAFFIC
668
PRODUCT PROT. F FREIGHT PACKAG. W TIE-DOWN HOOKS
723
TRUNK COVERING
725
CHROME LOOK ROOF RAILING
736
TRIM PIECES - WOOD ASH BLACK
806
AEJ 25/1
818
CD SINGLE DRIVE
840
DARK TINTED GLASS
846
SCUFF PLATE IN ALU-APPEARANCE WITH RUBBER STUDS
871
876
INTERIOR LIGHT ASSEMBLY
877
AMBIENCE ILLUMINATION
888
LOCKABLE LOADING FLOOR
889
KEYLESS - GO
890
AUTOMATIC REAR-END DOOR
893
KEYLESS START
900
EXTERIOR CHROME PACKAGE
913
AIR-CONDITIONING SYSTEM FOR HOT COUNTRIES
916
FUEL TANK WITH LARGE VOLUME - VOLUME 1
919
AIRCON COOLING POWER PACKAGE
927
EURO 6 TECHNOLOGY EXHAUST GAS CLEANING
989
IDENTIFICATION LABEL UNDER WINDSHIELD
05B
OPERATORS MANUAL AND SERVICE BOOKLET ENGLISH
0V3
SPEED- + LOADINDEX 101W
1A6
4-CYL. DIESEL CONVERTER
20A
EHS GENERATION
220A
LEATHER
221A
LEATHER - BLACK/ANTHRACITE
23P
DRIVING PACKAGE
251B
DIGITAL SERVICE BOOKLET
2A2
CONVERTER VERSION 3
30P
COMPARTMENT PACKAGE
335B
INSTRUMENT CLUSTER/HU LANGUAGE - ENGLISH
3A7
ASSEMBLY, ACTUATORS (THREE WHEELS)
3U1
EUROPE/CIS COUNTRIES/MONGOLIA HEAD UNIT
41R
LIGHT ALLOY WHEEL 5 DBL-SPOKE DESIGN 20" ALL-ROUND
51A
TORQUE DISTRIBUTION 31/69
51U
BLACK FABRIC ROOF INTERIOR TRIM
5A1
ELECTROHYDRAULIC CONTROLLER UNIT-CONVERTER
5P6
CONTROL CODE MARKETING
6A2
JOINT FLANGE W/ GW 110 / 3, 3-ARM X 110
775U
IRIDIUM SILVER - METALLIC FINISH
7A1
DIFFERENT LENGTH OF TORQUE CONVERTER HOUSING
806 *1
651.9__ 20120720 AEJ 25/1
806 *2
253____ 20111202 YOM 15/1
8U7
REAR SEAT BELT WITH BELT FORCE LIMITER AND SOFTST.
901L
AUSTRALIA ASSOCIATION
9XXL
AUSTRALIA / PACIFIC
A030
OIL OFFSET QUANTITY +300GR OIL
A09
CO2 OFFENSIVE
A11
ALTERNATIVE INJECTION
B03
DIRECT START / ECO START/STOP FUNCTION
B59
TRANSMISSION MODE SELECTOR LEVER (AGILITY SELECT)
F253
MODEL SERIES 253
FX
SPECIAL VERSION
G041
TRANSMISSION CODE VERSION 41
GA
GA7
HA
REAR AXLE
JVM
PLANT CONTROL CODE
JVO
PLANT CONTROL CODE
K11
ADAPTIVE STOP LIGHT FLASHING
K13
CONTROL CODE FOR SERVICE INTERVAL 25000 KM
M005
VEHICLES WITH 4-MATIC-/ALL WHEEL DRIVE
M014
ENGINE INCREASED PERFORMANCE
M020
BLUETEC
M22
DISPLACEMENT 2.2 LITER
M651
R4-DIESEL ENGINE M651
ND5
CONTROL CODE BREMEN PLANT
P17
KEYLESS-GO PACKAGE
P23
EXTERIOR LUXURY PACKAGE
P44
PARKING PACKAGE
P49
MIRRORS PACKAGE
P75
BASE PACKAGE, INTERIOR
R
RIGHT-HAND STEERING
R01
SUMMER TIRES
R66
TIRE WITH RUN-FLAT PROPERTIES
U01
REAR BELT STATUS INDICATION
U10
FRONT PASSENGER SEAT WITH WEIGHT SENSING
U12
FLOOR MATS - VELOUR
U22
LUMBAR SUPPORT ADJUSTMENT
U25
ILLUMINATED DOOR SILL
U35
12 V - SOCKET IN LOAD SPACE
U40
CARGO NET BEHIND FRONT SEATS
U60
PEDESTRIAN PROTECTION - ACTIVE ENGINE HOOD
U77
DIESEL EXHAUST TREATMENT BLUETEC SCR GENERATION 2
U85
LARGE SCR TANK RESERVOIR
VL
FRONT AXLE HALF, LEFT
VR
FRONT AXLE HALF, RIGHT
