2021 GLC slamming into gear in manual mode?
BMW 328i
I bought a used 2021 GLC 300 4matic with 17k miles last week. Usually I leave the vehicle in comfort mode but I decided to see how manual mode would work. I was driving at around 20 mph and decided to downshift from 3rd to 2nd. I clicked the down paddle and nothing happened so I clicked it again, and then I have probably the most severe jolt I've ever felt as the car slammed into a lower gear. What in the world? Is this normal for this car?!? Is it possible to overrev the car by accident? I've never had an automatic car that would downshift farther than the engine could handle.
I'm coming from BMW so I realizerealized X3 will probably have much better transmission tuning and performance, but is the transmission really this slow to shift and this harsh?
I have a 2021 and drive in manual fairly often. I just don't really like the normal "auto" shift points. This has never happened to me when downshifting. This isn't the fastest transmission in the world, but it has always been super smooth for me, in all modes, even sport/sport+.
BMW 328i
Interesting. Not sure what I did to make it do that, but I couldn't reproduce it when I tried to. Good to know that someone else said it's not a super fast transmission. I'm used to the ZF8 in BMW and the shifts on those units are instant and that's what I'm used to. I put the GLC into sport mode and the shifts were more of where I wanted them to be in that mode so I don't see a need for the manual shifting.
Received 2,495 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
That being said, welcome to Mercedes-Benz and congrats on your vehicle.
To answer your question on the hard shift you felt, it is because the transmission was probably upshifting (or ready to upshift) and then you wanted it to downshift so it hesitated and when it did downshift at the last minute when your vehicle speed was almost out of the range the optimal speed for the gear, it had no choice but to force a shift because you insisted.
Edit: Another thing is, modern MB transmissions to a certain a degree does adaptations. Since you said you brought the vehicle used. The previous driver's driving style might mismatch with yours and therefore the transmission is confused. Drive it a bit more and it will eventually learn your style of driving.
BMW 328i
Received 3,833 Likes
2019 C63CS
Just kinda adding to what was said above. Regular Mercedes-Benz models aren't really meant to be driven in manual mode much. That's partly evidenced by most of them lacking a button to activate permanent manual mode. You have to configure and use Individual mode to keep it in manual mode. Just using the paddles puts it in temporary manual mode, which quickly reverts back to automatic. AMGs on the other hand are meant to be driven in manual mode and have a button to put it in manual mode and leave it there at any time and they also don't automatically upshift at redline, which is commonly referred to as a true manual mode like a manual transmission minus the clutch pedal. The 63 models also have a clutch instead of a torque converter to further underscore the performance nature of the car. Manually shifting a torque converter automatic is rather numb most of the time. The ZF8 is no exception. It might shift faster than the 9G Tronic in regular MBs, but it's still numb.
Received 1,605 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
The downshift is also influenced by how hard you are braking and other factors. Do you have 4matic?
Also, when you leave it in automatic, the transmission learns your driving style and adapts. So if you drive aggressively for a while, it will shift more aggressively.
But no, you can't overrev the car by accident.
BMW 328i
You were probably driving faster than first gear would allow without exceeding Red line. The car will lock out a downshift if it would overrev the engine, until the car slows enough. Then when you do downshift, you're immediately spinning the engine at Red line, and that would probably feel like a jolt.
BMW 328i
Theres an M button in the center console that puts the car into permanent manual mode, and it has paddle shifters, so I figured it was OK to shift manually.
The ZF8 is used in all BMW modBMs, even the high end M models. It's about the fastest transmission I've ever used, including DCTs. I wish Mercedes would have used the ZF8 instead of designing their own 9 speed. Though the 9g tronic isn't bad by any means.
Last edited by W205C43PFL; 03-30-2022 at 09:27 PM. Reason: added another model to the question
BMW 328i
Yes, its a GLC 300 4matic. All of the GLCs I've looked at have the manual button on the center console to enable full manual control. Mine is a 2021, maybe the pre-facelift models didn't have them?
BMW 328i
It was so harsh, but yeah that's probably what was happening. I wasn't accelerating and I wanted to downshift. I haven't had the same issue again. Just learning how the car works. I've been driving BMWs for a very long time life so I'm very accustomed to how they behave and it's weird to drive another brand.
2019 C63CS
The ZF8 is actually rather slow. 200 ms shift times, compared to the 50 ms of a sport DCT and less than 100 ms of AMGs Speedshift MCT. Seems fast, but 200 ms is still human perceptible, but not 100 ms or less. Not talking about additional lag here between clicking the paddle and the transmission actually executing the shift, that's a whole other topic. The ZF8 is a common complaint with the M5 and M8, so much so that BMW M went back and reworked the software for the M3/M4, but the verdict is that it's still numb. MB/AMG still developing their own transmissions and specifically the AMG multi-clutch transmission is why I like the brand actually. Everybody else is abandoning their DCTs etc. in favor of the ZF8 and every car starts feeling the same. I personally dislike anything with a torque converter unless it's just a plain commuter car. The new M cars all using the ZF8 is a major reason I'm not interested in them. I think a performance car needs to have a clutch for proper drivetrain response. AMG still gets this, at least in the 63 models.
However, we are talking about the GLC 300 here, which is not a performance model, so comfort is what it is tuned for. Hopefully, the harsh shift was a one off and it just needs to learn your driving style.
Thanks for your reply, I didn't know GLC 300 had a manual button in the centre console.
