Open pano sunroof but not sunshade
Old Jun 11, 2022 | 03:56 PM
GroovyGeek's Avatar
GLC300
Is it possible to open the pano sunroof without retracting the sunshade? Seems to be an all or nothing set-up
Old Jun 11, 2022 | 05:53 PM
MBguy013's Avatar
Veteran: Marine Corps
2021 GLC 300 4Matic
You can only vent the roof. If you push up on the lever, the shade should retract a few inches and then the roof opens in the vent position.
Old Jun 14, 2022 | 10:28 AM
dalazernet's Avatar
2020 GLC300 4MATIC
In order to prevent stretching of the material, whenever the sunroof opens, whether it is opened fully or popped up in the vent position, it will roll back the fabric fully first. Different if you had a regular sunroof since that is not a mesh fabric and has vents built-in so that it can stay closed while the sunroof is popped.
- Eric
Old Apr 22, 2025 | 12:38 AM
Cornucopia's Avatar
ML63 AMG
- Eric
Sad but true unfortunately.....😢!!
Old Apr 22, 2025 | 08:22 AM
W205C43PFL's Avatar
- Eric
Oh so that's why, always wondered...
Old Apr 22, 2025 | 11:38 AM
mikapen's Avatar
- Eric
I thought the slight opening was simply to let the air out (vent).
Old Apr 23, 2025 | 04:51 PM
W205C43PFL's Avatar
If you meant ventilation mode, yup, it also adjusts the opening based on speed but I think you already knew that : )
Old Apr 23, 2025 | 05:48 PM
DanD.'s Avatar
2018 GLC 4MATIC
This is very annoying, drives me crazy as it constantly moves. Is there a way to disable it ?
Old Apr 23, 2025 | 07:16 PM
W205C43PFL's Avatar
Not official through a button or a setting in the infotainment but likely through a third party coding solution.
