Installed invisible dashcam that connects to rainsensor for power, now issues
https://www.aliexpress.com/item/3256802384387317.html
It connects to the rainsensor for power, which is super convenient as well. After I connected and tested it out, I noticed that the wipers would come on for no reason (wipers are set to auto level 1 or 2).
Now everytime I start the car, as soon as I put it in drive, the wipers will wipe once.
I've read that some mercedes models actually do that all the time and it's normal for wipers to turn once when you turn the car on (if you left the selector in auto sensing).
However, I never had this issue without the dashcam on. I removed the dashcam, connected the rainsensor back and the issue is gone.
So, 2 questions. Does your GLC turn the wipers on when you put it in drive and if not, what could be causing this?
I like the dashcam but won't keep it if I can't figure out why the rainsensor is acting up? Needs recalibration perhaps? How?
I reseated the connection multiple times. I know the rainsensor is getting power as well because the light sensor works (headlights turn on at night) and rainsensor will wipe if I put water on the windshield.
Is it possible to wire the cam to the fuse box, not to the rain sensor? I spend a couple of hours wiring the cam that way but I am positive that no original equipment would be affected by the cam. BTW, wiring into the car directly may cancel factory warranty on electrical equipment ...
Is there an additional power source in the original MB plug?
Much safer to wire to the fuse box with separate fuse, IMO
