2018 glc 300 crankshaft sesor location and replacement
Thanks in advance
Some are saying it’s in the passenger side
Any other help is greatly appreciated.
And is it hard to replace, do you have to remove the catalyst converter?
Problem is that i had a P0016 code camshaft crankshaft correlation bank 1 sensor A , I changed both camshaft (easy job) crankshaft sensor (hard) and still get check engine after I cleared code, read code again and still P0016 any help please, could it be the timing chain?
Cam solenoids
Chain stretch
Chain tensioners oil pressure failure
Camshaft position plate slipped
The above are candidates for the code. Do you have misfire, rough idle, steam from the exhaust, smoke from the exhaust, brown sludge under the oil fill cap, or bubbles in the coolant reservoir?
On my car, if the job is relatively easy or it is purely mechanical, I'd do it (changed leaking sunroof drain and door locks on my previous Q5, for example).
In your case, in addition to various sensors, stretched chain, tensioner problem, there could be wiring problem(s), from open circuit to intermittent loss of contact in bad plug or even bad computer/module.
So, instead of throwing parts into the vehicle, I would consider taking it to a specialist.
Please do not consider me as a "dealer only" person- I am all 100% for DIY repairs, but within my capacity.
Cam solenoids
Chain stretch
