Rx 350 or GLC 300
Maybe you want to ask “should I buy GLC instead of RX”, then I might be able to respond with yes or No.
You state, “I hate RX” and “truly love GLC”. Seems to me you already made up your mind. And which car does not have one or the other issue?
This is a Mercedes forum and I for myself would never buy Japanese, …… but to each their own.
When you go to a forum, you're going to find problems. Some will scare you. Many might not apply but you won't know because you don't know when a revision was made. Case in point. I bought a 2012 MB E550. Got on the forum and found so many reporting studdering brake problems at varying mileage. I started collecting data on what they drove and when the problem occurred. It was apparent that it was an underdesigned rotor that overheated and warped the rotor but it didn't apply to me because the only E550 (less than 5% of all E-class) had the upgraded Bembo brakes assembly. I also had an 2006 E350 that had the best feeling brake system on earth but the SBC (servo brake controller) can fail unexpectedly and you will lose all brake assist instantly. I read reports of it happening but not to everyone. MB extended the warranty for 10 years but no recall. Scary but it never failed on me.
For some, the cost of ownership of a MB is going to be unbearable. To those I say thanks for looking but please live within your means. This is a car has a finite life. In practicality, 10 model years in my opinion before a minor accident, through no fault of my own, can render it to totaled by insurance definition. I EXPERIENCED THAT TOO. That doesn't mean old MBs are no good but the mindset to address worn parts that cost more than the book value is a tough line to cross for some.
Good luck.
Good luck.
No, no problems at all in our '19.
I think it's prettier than a Lexus too, inside and out.
I owned RX300 & RX330 (V6) for ~15 years and than switched to 2016 GLC300 (4 Cylinder Turbo).
RX's needed one repair (Oxygen sensor) in 15 years, never had any breakdown. I owned GLC300 for 6 years, no repair. However, I paid far more in routine maintenance (at dealership by choice) in 6 years of ownership than I paid for RX's in 15 years.
I now picked another RX since I wanted to wait for the arrival of EQC ( the EV version of GLC). I am not a badge fan, but GLC was far more superior (in esthetics and ride) to RX's.
4 Cylinder Turbo are now adopted by nearly all manufactures but you can pick a new 2022 RX with V6 engine.
The GLC has a 4 banger with dubious genealogy related to the M274 engine which has a reputation for fatal piston cracking. MB claims to be leaving ICE vehicles behind and going all-EV. This means their commitment to ICE products is declining. I wouldn't want to own a product which a manufacturer is losing passion for.
Consider instead a BMW X3, Porsche Macan or Genesis GV70.
You have numerous members tell you that they have no issues with their GLC, and one member telling you there is an issue with the M274 engine. How valuable is that? Chassis mentions this EVERY chance he gets.
Chassis tells you that MB reliability is at the bottom of the barrel, but for some reason still driving an MB????
Yes there have been reported issues about the M274 engine, but it certainly does not mean that every engine has these issues, nor does anyone know how the engine was treated PRIOR to the failure (properly maintained, high octane gasoline, regular oil changes, etc.)
I recently had a C300 with the same engine, had 104k miles and was meticulously maintained with no issues whatsoever!
I have had numerous BMW’s in my household, because the wife just loved driving them. I finally convinced her to go MB, as all BMW’s we had have been very unreliable and high on maintenance. The last one we had and I finally got rid off was a 2011 X5, which cost me a fortune to keep it running as all kinds of stuff constantly broke.
Is a Porsche really more reliable and lower on maintenance? Not sure, never had one, but would think this not to be the case.
That shouldn't be a concern for OP if as they stated they will be looking for a 2023 to test drive, if that is still the X253 (and not the X254, which I thought that is the first model year of the X254? but it was never recommended to get first model year vehicle, that car also have a relatively new engine, the M254 with the rather quirky? if I should say, 48V hybrid system) ) then the X253 should be reliable as that is the end of the generation which means most if not all issues should be resolved, at least that is what usually happens.
The facelift X253 in North America (if OP resides in North America) starting 2020 GLC 300 had the M264 anyways which the 2019 C 300 and 2019 E 350 also got so the M274 issue doesn't apply to OP.
The GLC has a 4 banger with dubious genealogy related to the M274 engine which has a reputation for fatal piston cracking. .
MB ranks above average in the 2021 JD Power dependability rankings of 3 yr old vehicles. Top is Lexus (81 problems per 100 vehicles), MB reports 122 faults per 100 vehicles while the industry average is 163 per 100. The real "bottom of the barrel" is Land Rover at 244 per 100. MB is subjectively a more sophisticated vehicle than a Lexus but sophistication=increased complexity=greater potential for problems. The OP will need to assess if any perceived increase in sophistication is sufficient to overcome the relatively minor potential decrease in dependability. For me it certainly was.
The piston cracking issue on the M274 is completely false because Low Speed Pre-ignition (LSPI) which causes piston cracking affects ALL turbocharged, direct injection engines regardless of brand. It can be easily addressed by using the appropriate API-rated oil. Please refer to the thread on this site titled "Cracked Piston Cylinder 2" which covers this issue,
https://www.classaction.org/news/mer...ng-m274-engine
Thank you.
Now it's a completely redesigned engine with few internal parts retained. Different block, head, pistons, hollow crank and lubrication system.
If I succumbed to all the possible Class Action suits available to me, I'd be filling paperwork for a dozen appliances, jacks, and assorted fictional Lawyer Support Causes.
It's a Nothing-burger.
