how to reset easy entry-exit
Old Feb 3, 2023 | 05:22 PM
GeneS's Avatar
2022 GLC 300 RWD
On my 2022 GLC300 w253 the easy entry-exit stopped working after dealership replaced a blind spot assist sensor.
It is turned on in the menu but does not move the seat back or steering wheel in on stop engine and open door.
Any one know how to reset this?
Old Feb 4, 2023 | 11:25 AM
GeneS's Avatar
2022 GLC 300 RWD
Got figured out from another forum.
put car in accessories position 1st push on start.
moved seat to half way of up-down, forward and back
steering wheel about half way up and down, in and out.
turned off car. under front seat un plugged and plugged back in
1 at a time 4 connections to seat control.
restarted car, easy entry/exit works like it should
any bodies guess which thing corrected it, But
better than paying dealership to reset
Old Feb 8, 2023 | 02:26 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
soft-crash tips
Congrats on resolving your soft-crash seat issue. Everyone likes a quick fix.
For everyone else: do not go around your car unplugging live modules and expecting miracles, instead.... :
1-- Buy a $150 scanner to retrieve fault codes and reset issues if necessary.
2-- Use a float charger to keep up battery voltage. Car charging system may not be working well. Check if you have extreme battery drain while driving.
3-- Reboot computers by disconnecting battery. Indulge often in this step for free miracles.
Marginal voltage causes networked modules to become soft crashed until reset. Main targets are SAM's that are always powered 24/7 to wake up all others when needed.
Please don't unplug live systems... SRS airbags connections under seat area.✌️
