Check Brake Wear Pad
Old Jun 12, 2023 | 12:37 AM
wagga_ria's Avatar
B180 (W245), A-180 (W176) & GLC-250d (X253) <previously GL320CDI (X164)>
Hi All
Alarm just pop up on the display.
I serviced the car 2 months back and had a reading of 5mm and 6mm on the front and rear respectively.
I thought those values were ample meat on the wear pad.
What's your thought?
Regards
Waz
Old Jun 12, 2023 | 07:28 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
in my experience the indicator lights with about 1000 miles left on the the pads; your 5 & 6 mm readings sound about right. I'm a little particular about the brake pads I prefer and since they're not OEM, MB Service won't install them, so I always appreciate the heads-up as it alerts me to order new pads, and whether to order fronts, rears, or, in your case, both.
Old Jun 12, 2023 | 07:30 AM
eddieo45's Avatar
in my experience the light comes on with about 1000 miles left on the pads, so your 5-6mm estimate was about right.
Old Jun 12, 2023 | 09:33 AM
wagga_ria's Avatar
Thanks mate. I am not bother with OEM. Not mechanically inclined, so getting a local workshop to install them.....
I thought 5mm looks thick.... But I guess not for the GLC.
Old Jun 12, 2023 | 10:00 AM
eddieo45's Avatar
A new brake pad is about 8-12mm, and 3mm is about as thin as you should let them get. For future reference you can look at that 5-6mm estimate as an opprtunity to order new pads before the wear indicators are activated, saving you $10-$20 each.
Old Jun 12, 2023 | 04:36 PM
abacnus's Avatar
2020 GLC 300 4Matic OffRoad
In my case, the "Check Brake Pads" message turned on for the rear brake pad at 38000km, and I replaced the rear brake pad at 42000km, it still had 1mm of meat.
The rear new pad Thickness is 16.4 mm
Checkout my story at: https://mbworld.org/forums/glc-class...s-message.html
