GLC300 Oil Leak
Anyway, 3000 miles ago the plastic cladding under the car was dry and clean. This time when I took it off there was a spray of oil on it. Seems to have a leak or seepage front engine somewhere. I cannot pinpoint it, but seems to be in the area of the front of the engine. It is not so bad that she will run out of oil and I will check it, but I don’t like it. Its not the cam adjustment sensors. Have another Merc and know about those.
Cannot find anything on the TSB’s about oil leaks. Might have to take to dealer, but it’s a bit of a drive. If I can fix it, so much better.
Are there any known issues with this car with oil leaks?
The leak is more of a spray, so its difficult to find.
I know there is an old recall for oil feed lines that may leak. But this car was not recalled for it.
When I did tranny oil change a few months ago, I've notice wet spot at the back of the engine but I wouldn't call it a leak. My GLC has 40K mikes on it.
P.S. i do change the oil every 2.5K or 3K miles, so don't judge me ))
Can see the oil on the edges of the hose at the bottom. I cleaned the plastic pan a week or so ago, so no oil there. Taking to dealer in few weeks. But something there is leaking
