2021 GLC 300 issue
I recently picked up a 2021 GLC 300 which came fully loaded with all the goodies for a very good price (WARNING) which keeps the miles down on the SL. HOWEVER I noticed that the car throws a constant P219C code and then just yesterday an 0301 (Missifre Cylinder 1) and the whole damn car felt like it was going to fall apart. I cleared the code and carried on... the car behaved fine since P219C seems to come back though, the plan is to start by replacing the plugs and then check injectors if this issue is not resolved, despite being a 2021 the car has very high mileage at 79k so I figured I'd start with the plugs, I'm debating about purchasing an MB extended 100k mile warranty that should be good for 1 year. I've done some research and I'm kind of hoping that this isn't a cracked piston... who'd have thought that a near 20 year old Mercedes AMG with ABC suspension is more reliable than a 3 year old modern Mercedes. Any advice/help is appreciated!
https://mbworld.org/forums/glb-class...ght-p219c.html
https://mbworld.org/forums/glb-class...nder-head.html
https://static.nhtsa.gov/odi/tsbs/20...41534-0001.pdf
Just an update regarding the issue... So, after day 1 at the dealership the car behaved and they found no errors... I then described the issues again after getting a bit pissed off, poor fuel consumption, check engine light, vibration when using the hold feature at a stop sign/traffic light, the occasional misfire when driving etc... They took the car for a 10-15 mile test drive as I told them a 2 mile test drive won't do anything. The service advisor said that I was spot on... surprise surprise... It's a faulty fuel injector, the block and the head are fine. They are replacing the fuel injector tomorrow morning and then do a road test... They even offered me a job... I mean, honestly, I'm sure there are procedures to follow as an MB tech, but if you have been advised with codes P219C and P0301 and just recently P0202. You'd research those codes and knowing the M2XX Engine you'd figure it out pretty quick. Thankfully the car is under warranty and I don't have to pay a dime. Stressed but, Hopefully it all works out.
Did they coincide with Mercedes error codes?
Just trying to figure out why they didn't investigate your evidence.
