How to replace door arm rest?
Old Apr 28, 2024 | 04:03 PM
bluenuys's Avatar
glc 300
I have a replacement arm rest but am puzzled on how to replace it.
It looks like most of the attachment points are glued into the door panel with these dime-sized pieces of ABS. But the replacement armrest only has the stems, not the "heads"
I guess at the factory they use some kind of head machine to quickly bond the armrest to the panel with round ABS buttons.
Does anyone have experience on this? am I better off trying to screw metal screws into the stems for a conventional attachment, or should I try to create my own ABS "heads" and try to bond everything using ABS cement?
glc 300 front driver door panel, backside, arm rest connections highlighted.
Old May 1, 2024 | 07:54 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
I swear I posted a reply yesterday....oh well.
I think you're in good shape for a few reasons:
  • you found the part, which I haven't seen listed separately
  • you're aware of your options - glue or screws - and willing to give it a go
  • you came to the right place for opinions!!
I think THIS W203 THREAD could be helpful, with photos, removal instructions and even a glue recommendation. I'd try the glue first, as you could later screw right through your glued spots if they don't hold.
Old May 1, 2024 | 11:24 AM
bluenuys's Avatar
glc 300
Sadly, i further marred the vinyl on the panel while taking it apart. Maybe i should stop drinking vodka before working on the car.
I have ordered a full replacement panel. I just have to swap the decorative trim with the speaker grill.
