GLC Dashboard removal
As the title states, I'm looking for advice on how to remove the upper dashboard of the car. The trim has developed an extremely irritating wire/plastic tapping noise that's directly under the upper dashboard.. It's not particularly loud but it's just one of those irritating noises, I've removed the glove box and tried to feel for anything that could be causing this, but I couldn't. I figure removing the upper dashboard would allow me to find where this problem is and I can fix whatever is causing this frustrating noise... Simple solution would be to turn the music up, but It would be nice to have the occasional conversation with any passengers. The noise appears to be located around the passenger side (US) Air vent... Also, I'm sure the Pirelli Scorpion runflats don't help. Thanks for your help.
Is this noice permanent? I have some ticking rattling sound when car gets up to 38mph.
Its more like ticking sound but much faster rate. It disperse when seed is below 35-38mph. Very annoying.
But my problem is related to a speed and its at the same rate. Im afraid its some valve under the hood or even injector.
Good luck and keep us updated. I really like to get under the dash too.
One of the ac pipes under the hood located
Near to wipers motors was kind of loose, i thought this is it. No its not it.
Also: i removed center console was thinking I can get access to a center or sound should be louder and easy to pinpoint. No luck.
I hope you will find it. Where do you put weight?
