GLC Class (X254) Produced 2023+
2024 GLC driver's side fuse cover
Old Jul 22, 2024 | 03:04 PM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
Trying to find a switched 12v fuse to run my dash cam. Manual says the fuses are behind this panel and to pop it off. I carefully moved the soft molding off it. There is a lot of resistance to moving it. Anyone been successful in getting it off? TIA
Old Jul 23, 2024 | 04:32 PM
pjw1967's Avatar
I got it off. Pried it out from the edge closest to the steering wheel. Used the original power cord plugged into the outlet in the cargo area. Having the fuse panel off allowed me to fish the power cord from behind the kick plate.
Old Aug 1, 2024 | 05:58 PM
dpalm's Avatar
2024 GLC 300
Which fuse #’s did you use for the AC and for battery connections. I’ve got a Blackvue dash cam I’m wanting to install. Thanks.
Old Aug 1, 2024 | 09:46 PM
pjw1967's Avatar
When I got the panel off it occurred to me that I couldn't direct wire to a fuse because the camera is 5 volts. There are kits on Amazon for this. I haven't ordered one yet. For now I am using the original power cord plugged into the 12v socket in the back.
Old Aug 2, 2024 | 08:23 AM
Gitzer's Avatar
2023 GLC 300, 2021 VW ID4
Do you know there is also a 12v socket in the front, on the left side of the passenger foot well?
Old Aug 2, 2024 | 09:23 AM
pjw1967's Avatar
Thank you. I did not know but now I do. Attached is what MC refers to as the MSRP. It's the window sticker with option codes. I underlined the option U35 for the cargo area 12v socket. I have stared at this for a long time but cannot see where the footwell 12v is mentioned. But thanks again to you I found it.
File Type: pdf
