GLC Class (X254) Produced 2023+
Canadian winters and PHEV
Old Oct 17, 2025 | 04:57 PM
bigpaparay's Avatar
Does the GLC350e warm up the engine oil, when driving on electric? I'm worried that by running it in hybrid mode, the a cold engine will kick in with thicker oil at high speeds, and cause premature engine wear.
In Canada, the winters can get quite cold...
Old Oct 17, 2025 | 10:37 PM
404CPE's Avatar
I think there is a heat exchanger for the engine that is heated by the electric drivetrain. I want to get a technical document from M-B about this so I can learn more about it all. Turn the energy flow screen on when EV mode and show coolant temp under "engine". It's usually 50 degrees or more.
Old Oct 18, 2025 | 02:21 AM
Bwds7's Avatar
I'm also curious about this. It seems like a valid concern, but you would think a company like Mercedes has designed it in a way that is safe for the engine.
I did a quick test myself this evening. I drove the car in electric mode for about 15 minutes and took a picture of the oil temperature (first pic below). I then put the vehicle on battery hold mode and took a picture of the oil temperature after 5 minutes of driving (second pic below). As you can see, the oil temperature was low on electric mode and increased when I turned on battery hold mode. It was about 13 degrees Celsius outside when I did this test so we will have to wait and see how it is in the winter.
Electric Mode
Electric Mode
Battery Hold Mode (after 5 minutes of driving)
Old Oct 19, 2025 | 01:20 AM
404CPE's Avatar
Oil and coolant temp look more or less identical to me. Anyway the EV mode oil temp is fine for a quick startup.
Old Oct 19, 2025 | 01:43 AM
Bwds7's Avatar
Perhaps I'm not reading the meters correctly but to my understanding the oil temp on Electric mode reads just above 20 degrees Celsius and ~60 degrees Celsius after being on Battery Hold mode for 5 minutes. The question is, will the oil be heated in colder weather when driving in Electric mode? Is it safe for the engine to turn on mid driving with oil temperatures below 20 degrees Celsius or would it be best to pull over when possible and let the engine and oil warm up a bit? I understand it won't be an issue when driving in Electric mode but say the battery is depleted while driving and you suddenly go into hybrid mode.
Old Oct 19, 2025 | 12:00 PM
404CPE's Avatar
Oh yeah you are right. Sorry. The coolant temp is steady under both scenarios.
Old Oct 19, 2025 | 01:36 PM
bigpaparay's Avatar
Thanks for the replies so far.
I did a drive today. Outside air temp of 21 degrees C. Mostly city traffic for a 30 minute drive and started out with a 85% charge.
First 5 min on electric (which was defaulted)…oil temp stayed the same at 21 degrees C (which was the outside air temp).
The next five minutes, I put it in hybrid mode. Still no change in the oil temperature.
After five more minutes, I put it in Battery Hold, and immediately the engine kicked in, and the oil temperature started to rise accordingly.
Now, I’m not sure if there’s any literature out there to suggest an automatic preheating of the oil below a certain temperature.
The coolant temperature did rise slightly (about 10 degrees if I were to reckon off the scale).
Old Oct 19, 2025 | 01:55 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
If I am interpreting your reporting so far, the outside air temperature or ambient, is the same as the oil temperature, when the combustion engine hasn’t run yet.
This would lead me to believe that the combustion oil temperature, at the time of the start, would be the same temperature as the ambient air.
In a garage, that might be above freezing during the Canadian winter.
But on the street or in the driveway, carport, what have you, a dipstick heater might be just the thing.
Old Nov 10, 2025 | 06:23 PM
Bwds7's Avatar
I took a couple pics on my way home from work today. My car was parked outside for about 12 hours. It was -3°C today and when I turned on my car, the coolant temperature was 11° and the oil temperature was 5°. After about 30 minutes of driving on electric mode, the coolant temperature rose to 40° and the oil temperature dropped down slightly to 4°. I had 17% battery remaining when I turned off my vehicle. So it looks like the oil is not heated while driving on electric but I'm curious if it will start warming up the oil if the battery percentage is less than 5%. I will try and go out for a drive later tonight and see if the oil temperature changes before the battery depletes.
Temperatures when I turned my vehicle on after sitting in -1 to -3°C for 11 hours
Temperatures when I turned my vehicle on after sitting in -1 to -3°C for 12 hours
Temperatures after 30 minutes of driving on electric mode
Old Nov 10, 2025 | 09:14 PM
Bwds7's Avatar
Update:
I depleted my battery and the oil temperature remained the same as it was when I turned on the vehicle. The oil only started to warm up once the ICE was running.
Question for any mechanics on this forum: is it harmful to have your engine turn on while driving with an oil temp below 5°C?
Old Nov 10, 2025 | 10:48 PM
404CPE's Avatar
Oil temperature is not the key, but rather its viscosity when cold. And that is very low....I believe that they specify 0W40, which is perfect for low temperature flow.
Old Dec 21, 2025 | 05:16 PM
paulroisin's Avatar
2025 GLC350e
Canadian winters
I live in Minnesota and have found that when temperatures below 15 F /- 9 C the vehicle automatically reverts to Hybrid and turns gas engine on and Electric mode disabled. I have not found anything in manual about this.
