Lower module
There's only two options to lower the GLC. Lowering Links $199 or Renntech Lowering Module $1400. There's another lowering device that was seen on Amazon for $449 but it doesn't work with the MB touchpad interface. It only works for older Mercedes SUVs that have the Command keypad system as you have to input the values using the keypad (I reached out to the seller to confirm).
The Renntech Lowering module would be the best bet as you could adjust on the fly but it's super costly. The lowering links you have to remove them adjust it if you want to go higher or lower. I have my GLC at a perfect height to me, so I will not be adjusting any more unless I am going off roading (which I will never do).
amazon module
can work with touchpad interface and also with scrolling command controller, to check compatibility you can send them email with your VIN #
amazon module https://www.amazon.com/dp/B07C7G3J13 can work with touchpad interface and also with scrolling command controller, to check compatibility you can send them email with your VIN #
" as you must be affiliated or know the company for the module. I am the one who posted on the Amazon page about the GLC and watched the GL video. The response that I got was that it may not work for the new touchpad interface and I would need to send my VIN in. I sent my VIN in like week+ ago and have not heard back so I took that as it may not work. If you know something shoot me a PM to discuss further.
" as you must be affiliated or know the company for the module. I am the one who posted on the Amazon page about the GLC and watched the GL video. The response that I got was that it may not work for the new touchpad interface and I would need to send my VIN in. I sent my VIN in like week+ ago and have not heard back so I took that as it may not work.If you know something shoot me a PM to discuss further.
https://www.ebay.com/itm/282847463816?ul_noapp=true
I sent him my vin and he confirmed it will work.
I did 20mm in the front and 25mm in the rear and still comfortable in comfort mode . Harsher in sport + mode but still fine .
I love it !
I use it on my S coupe
"\Low " option is -32mm and that level is comfortable on comfort mode
