Anyone using wheels spacers to achieve better stance using stock 21's ?
Old Nov 20, 2020 | 01:42 PM
  #76
Gusman01's Avatar
M2
Anybody know the oem lug bolt length for a 2020? Trying to find out what size I’ll need for spacers.
Edit: never mind found it, it’s 48.5mm.
Old Apr 26, 2021 | 06:46 PM
  #77
ronb_01's Avatar
GLC63 AMG
I have 2019 GLC63 and having the same issues with my H&R Trak+ 20mm spacers, where my current oem lug bolts won't fit because of being too long. I'm unsure of length bolts I need to get for it to work. Should I do 48mm - 20mm and get 28mm bolts which would be shorter. I also got 25mm spacers for the back as well.
Old Feb 19, 2023 | 06:38 PM
  #78
humblehyper's Avatar
2024 E350
Hi, anyone with a 2023 AMG GLC 43 with stock wheels and tires that's on wheel spacers? I dont know what thickness to get
Old Feb 20, 2023 | 11:32 AM
  #79
2024 E350
Anyone know if this will work for my car?
https://www.hpamotorsports.com/produ...center-bore-vw
Old Feb 20, 2023 | 11:53 AM
  #80
lanoipat's Avatar
2010 Audi S4, 2019 GLC 43,07 BMW Z4 M coupe
I went with 15mm in all 4 corners .
You can go more aggressive but if you lower the car you may experience rubbing in the back .
Also think about when you are going to change tires and go with 265 front and 295 rear because you get more brand options .
Old Feb 20, 2023 | 12:04 PM
  #81
2024 E350
Hi, do you have a link on the spacer that you used? Thank you very much!
Old Feb 20, 2023 | 12:08 PM
  #82
2024 E350
Will this one work with the OEM wheels? I have these wheels, thank you again!
https://www.hpamotorsports.com/produ...62696149&_ss=r
Old Feb 20, 2023 | 12:32 PM
  #83
lanoipat's Avatar
Bought the spacers used on the forum from marketplace but they were from ECS tuning DR Series Wheel Spacers - 15mm (1 Pair) Black
ES#: 2730959
As for the studs ,i bought them from From 42 draft designs because I want it to be black and did not find them anywhere.
Black M14x1.5 Ball Seat Extended Lug Bolts
(Length: 60mm) 42-886-600
Old Feb 20, 2023 | 03:26 PM
  #84
2024 E350
ES#: 2730959
Thak you sir!
Old Feb 20, 2023 | 05:56 PM
  #85
2024 E350
@lanoipat do you have pictures of your setup? Just want to see how close to the fender is the 15 mm, thank you again!
Old Feb 21, 2023 | 11:16 AM
  #86
lanoipat's Avatar
Check post 56 on this thread . Not mine but same set up .
When you check pictures make sure the spacers are on GLC43 and not 63 because rims on 63 have different offset .
Old Feb 21, 2023 | 11:43 PM
  #87
2024 E350
His wheels are different than mine, thank you though.
Old Feb 22, 2023 | 11:06 AM
  #88
lanoipat's Avatar
If they are 21 , should be the same offset .
Old Feb 26, 2023 | 12:41 PM
  #89
2024 E350
Thank you!
Old Feb 26, 2023 | 12:44 PM
  #90
2024 E350
Originally Posted by LA_AMG_GLC63
no issues with rubbing. I’m on the stock 21’s, just ordered the lowering module, I’ll let you know how she rides when I’m lowered.
@LA_AMG_GLC63 did you lower your car already? No rubbing on 20 and 25 spacers? Thank you!
Old Mar 13, 2023 | 01:10 PM
  #91
2024 E350
@lanoipat hi, do you know if these will fit my car?
Old Mar 15, 2023 | 12:14 PM
  #92
lanoipat's Avatar
Should be fine .
No idea why the GLC is not listed .
Ask them to make sure but ppbly a typo .
Old Aug 1, 2023 | 12:01 PM
  #93
bot_lgnd's Avatar
2022 GLC43
Hey, was looking at getting spacer the same size for my 22 GLC43. How’s the fitment so far and what website did you order them off?
Old Apr 11, 2024 | 02:34 PM
  #94
Swissinn's Avatar
AMG GLC 63S
Yup!
Ditched the staggered set up. 275/40-21 all around.
Toyo Proxes Sport XL 107Y. 20mm spacer in the back. 12mm in the front. Airmatic lowering links all around. In comfort mode it sits 1 cm lower than what Sport + would be. Sport+ is very low now. Almost only for show and very aggressive cornering. I think it looks great.
Old Jan 3, 2025 | 02:41 PM
  #95
CA400's Avatar
C400
Bumping this to the top.
Will spacers from my C400 (W205) fit on a 2021 GLC?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
