Anyone using wheels spacers to achieve better stance using stock 21's ?
Old Jul 11, 2019 | 08:52 PM
affalterthought's Avatar
Blk/Blk GLC43 AMG WAGON
Has anyone done a wheel spacer/ extended bolt set up on a 43 (or 63) with the stock 21" (or 20") wheels?
I am aiming for a OEM+ style with a sportier drop and more aggressive stance.
My idea of aggressive is offset that achieves a flush with the fender dynamic with a drop that is devoid of "tuckage".
Any feedback and/or pictures to show the details of your set up would be greatly appreciated.
Cheers
AFT
Old Jul 11, 2019 | 11:31 PM
lanoipat's Avatar
2010 Audi S4, 2019 GLC 43,07 BMW Z4 M coupe
Cheers
AFT
If you go there and check thread #49 , a guy with a 63 did 20 front and 25 mm on 21 inch
https://mbworld.org/forums/glc43-glc...3-today-2.html
Old Jul 12, 2019 | 07:53 AM
cheers
Old Jul 17, 2019 | 09:47 PM
TOOGECKO's Avatar
AMG GLC43
i’ve Had my GLC43 for about two years now and believe I was one of the first few To install spacers, there was very little info at the time. Do a search on TOOGECKO and the thread should pop up.
Old Jul 19, 2019 | 03:47 PM
viper3ez's Avatar
GLC63
just decide how much you want to add to the offset and order spacers. your hub is 66.6mm
Old Aug 10, 2019 | 01:31 PM
That's one option.
Cheers
Old Aug 10, 2019 | 08:54 PM
viper3ez's Avatar
GLC63
FWIW, I am down to 20mm front offset from 28mm, then i added 10mm to front tire width to 275.
I added 20mm to rear tire with 315 width.
based on those numbers,
adding 12mm spacers to front and rear should get you about where I am.
Every 2mm added in wider wheels/tires is 1mm added in spacers. Tire and wheel additions are shared between inside and outside of tires
Old Aug 11, 2019 | 07:50 AM
Thanks Viper !!
Any chance you have a pic or pics showing a side shot ? Thanks for the aforementioned information. Any particular brand better than others ?
Old Aug 11, 2019 | 12:51 PM
scotchy's Avatar
Look at this guys Instagram for lots of pictures with stock 20's. Says he's 18mm front/25mm rear.
Old Aug 11, 2019 | 12:58 PM
scotchy's Avatar
Not factory wheels or tire sizes but this will give you something to go off of too. Look at post 6.
I'm 21mm more front, 24mm rear.
https://mbworld.org/forums/glc43-glc...ml#post7824642
Old Aug 11, 2019 | 07:36 PM
viper3ez's Avatar
GLC63
Rer is 315 on 30mm offset so aproximately 10mm further out the tire well than stock
Old Aug 11, 2019 | 07:45 PM
viper3ez's Avatar
GLC63
same configuration in 22" wheels i previously had on.
The front wheels here were 28mm or 30mm but 9" wide instead of stock 9.5". tire was 265 width. I felt it was too high. This is why i went down to 20mm offset in front for a true flush look plus the 5mm from going to 275 tires.
Old Aug 12, 2019 | 03:00 PM
Thanks for the pictures Viper. Might be the angle(s) but to me there seems like there is more room
to push them out even further. I am thinking if your car was lowered your wheels would still tuck.
Do they ? Either way thanks
Old Aug 12, 2019 | 03:29 PM
viper3ez's Avatar
GLC63
I am lowered. At a certain point you have to start caring about what the bottom of the tires are doing as you are pushing the top to line up with the fender.
Old Aug 12, 2019 | 06:41 PM
viper3ez's Avatar
GLC63
front
rear
Old Aug 12, 2019 | 07:18 PM
Yeah I totally get that. I don't want to compromise the wheel contact either. Thanks for the xtra pix. cheers
Old Aug 16, 2019 | 10:05 AM
TexasEd's Avatar
2019 AMG C63s Coupe
Cheers
AFT
Go with 12mm on both front and rear and you will attain a very nice, flush appearance. I had that setup before mounting Vorsteiner wheels. With the offset on Vorsteiners one does not need spacers. I am also lowered on H&R's. I am satisfied with the fitment.
Old Aug 17, 2019 | 11:58 AM
scotchy's Avatar
Looks like you have a C63, not GLC63??
Old Aug 17, 2019 | 12:19 PM
TexasEd's Avatar
2019 AMG C63s Coupe
That's true but the thread starter did not specify a model, he simply stated "43 or 63" which could be a C or GLC. I have a C but the fitment would likely be the same for the GLC
Old Aug 17, 2019 | 12:42 PM
scotchy's Avatar
True but it's in a GLC forum. . Totally different fenders/wheel size/offsets etc, very different fitment.
Old Aug 17, 2019 | 12:55 PM
TexasEd's Avatar
2019 AMG C63s Coupe
My bad, I thought I was in the C63 forum.
Old Aug 17, 2019 | 12:58 PM
scotchy's Avatar
No worries! Nice car!
Old Aug 17, 2019 | 01:47 PM
I have my module on its way just trying to determine mm and brand in spacers.
Old Aug 17, 2019 | 03:59 PM
scotchy's Avatar
FYI if you haven't seen it on other posts, 13mm is the minimum IIRC to clear the factory hub and seat properly.
I used H&R spacers and bought bolts from Otis.
Otis was hugely helpful and quick to respond to emails, possible they have other sizes of spacers too not listed.
https://otisincla.com/product-catego...wheel-spacers/
Old Aug 18, 2019 | 09:24 AM
Did you go with a floating spacer or a full Hub-centric with extended bolts ?
