GLC 63 Weistec BOV -installation?
Subscribe
Sep 25, 2019 | 08:20 AM
Did somebody install Weistec BOV on GLC 63? Any advise will be highly appreciated!
Reply 0
Sep 25, 2019 | 02:58 PM
Quote: Did somebody install Weistec BOV on GLC 63? Any advise will be highly appreciated!
I'd like to know as well
Reply 0
Sep 25, 2019 | 06:17 PM
I only see them for GLA's, CLA and A's all in the 45 series.
I am all for the sound of them if they make one for the GLC63s.
Reply 0
Sep 26, 2019 | 12:27 AM
https://www.weistec.com/m177-vta-adapter-system.html
Reply 0
I'll figure something out.
Reply 0
Sep 26, 2019 | 01:17 AM
The link to the video appears broken... would love to hear how this sounds.
Reply 0
Sep 26, 2019 | 01:19 AM
Quote: The link to the video appears broken... would love to hear how this sounds.
Oh it's only $150. F it. Ordered blind.
Reply 1
Sep 29, 2019 | 12:20 PM
Installed in 40 minutes myself! Quite easy actually? Removed plastic covers upfront, remove stock electronic valves, put Weistec valves and mount back stock ones using longer bolts provided. Put plastic covers back and you're done.
Reply 0
Explore
Sep 30, 2019 | 09:06 AM
Quote: Installed in 40 minutes myself! Quite easy actually? Removed plastic covers upfront, remove stock electronic valves, put Weistec valves and mount back stock ones using longer bolts provided. Put plastic covers back and you're done.
How does it sound?
Do you only need 1 if you have the bi turbo!
Reply 0
Sep 30, 2019 | 08:39 PM
it's sounds great and you need two for biturbo!
Reply 0
Oct 1, 2019 | 10:51 AM
Quote: it's sounds great and you need two for biturbo!
I called Weistech and they stated that it comes with 2. Did you get two for the $149.99?
Reply 0
Oct 2, 2019 | 12:01 AM
Quote: I called Weistech and they stated that it comes with 2. Did you get two for the $149.99?
Yes 2 in package. Install is 10 min
Reply 0
Oct 2, 2019 | 11:08 AM
Quote: Yes 2 in package. Install is 10 min
Do you have it? I think I am going to skip it based on researching various articles. Here is a pretty good summary of what I have been finding. Thoughts on your end?
This mod is total nonsense. The valve in question is not a blow-off valve. It is a priority valve (or compressor by-pass) that prevents turbo lag. Besides making more noise, letting that air escape to atmosphere increases turbo lag and deadens throttle response, because it defeats the action of the stock design.
Priority valves were first fitted to the Porsche 944 Turbo in 1988. Prior to that everyone used blow-off valves, where needed. Any company since, that made a good turbo system, used the priority valve setup. Audi, Porsche and Subaru are legendary examples. Priority valves are so important I actually welded fittings to my 1988 Celica GT-4 intercooler and intake box to adapt the clever Porsche 944/Audi part! Much improved the throttle response.
Now, racing turbo systems over about 2.5 bar do require a blow-off valve in addition to the priority valve function. Otherwise, the over-pressure in the intake risks splitting intercooler seams or blowing off hoses. The C-Class turbo systems are nowhere near requiring this mechanical pressure relief. The opposite is true. We want to keep that pressurized air working for us, not just **** it away.
Installing an aftermarket 'blow-off valve' defeats the clever function of the stock priority valve. The priority valve is there to remove turbo lag. It does this by recirculating the compressed air back into the atmospheric side. This keeps the compressor from stalling, so when you tip back into the throttle, it makes boost instantly. This is just as true at part throttle as full throttle. It works all the time.
There is also a very clever, simple delay spring built into the system, such that this factory priority valve system, once pulled open by manifold vacuum, resists closing for ~.1 to .3 seconds due to the resistance of this spring. This delay allows the turbocharger to spin up freely (no load) for an instant. As the valve comes completely closed, the turbine is now almost up to full rotational speed, so there is more boost available, much more when opening the throttle that without it.
If you want to understand this theory, put your hand over the suction of a household vacuum cleaner. The speed of the motor rises dramatically because, although still pulling a vacuum, it is doing no work (no air is moving). That is what the priority valve does for the turbocharger, specifically by adding pressure to the atmospheric side of the compressor wheel. It lets it freewheel momentarily and not loose rotational speed. Most important is the spring delay speeds up the turbine wheel further by there being no load on the compressor side.
Reply 1
Oct 2, 2019 | 11:12 AM
Yes I put it on for other reasons. I am pushing twice as much boost and I actually blew off my outlet gasket from turbo to intake manifold. I needed a way to release the back pressure from the turbo more quickly. If I was a stock setup with basic tune there is no point in having it besides the noise. I have not noticed any sort of turbo lag.
Reply 0
Oct 2, 2019 | 11:19 AM
Quote: Yes I put it on for other reasons. I am pushing twice as much boost and I actually blew off my outlet gasket from turbo to intake manifold. I needed a way to release the back pressure from the turbo more quickly. If I was a stock setup with basic tune there is no point in having it besides the noise. I have not noticed any sort of turbo lag.
I know you need it, with all your,the stock system won't keep up with your pressures.
After looking at what it truly is...isn't it just a fancier outlet? Wouldn't it be the exact same thing if you just plugged the intake hose and removed the outlet pipe and hose? Or, you could likely leave the outlet pipe.
Reply 0
Oct 2, 2019 | 11:22 AM
Here is a good installation video for anyone with a 63.
Reply 0
Oct 2, 2019 | 12:00 PM
Quote: I know you need it, with all your,the stock system won't keep up with your pressures.
Yes if you’d like I have the plugs because I didn’t have to use them because I have the Weistec air boxes. Basically it is the same thing except the stock pipe has a angle that doesn’t allow direct pressure leaving. If you want I can mail you my plugs
Reply 0
Oct 2, 2019 | 12:22 PM
Quote: Do you have it? I think I am going to skip it based on researching various articles. Here is a pretty good summary of what I have been finding. Thoughts on your end?
Wow. Thanks for that. Good thing I haven't installed mine yet. Anyways after watching some videos I can't say I'm a huge fan of the teapot-kettle sound.
Reply 0
Oct 2, 2019 | 12:37 PM
Reply 0
Oct 2, 2019 | 12:51 PM
Quote: Yes if you’d like I have the plugs because I didn’t have to use them because I have the Weistec air boxes. Basically it is the same thing except the stock pipe has a angle that doesn’t allow direct pressure leaving. If you want I can mail you my plugs
Naw, I think I will just leave the stock system in place.
Thanks for the offer though.
Reply 0
Subscribe
Currently Active Users (1)
