Replacement tires for 20 inch glc 43
Old Dec 15, 2019 | 02:02 PM
rinukon's Avatar
GLC 43 AMG
Already did a search of both forums and options on tirerack. The eagle all seasons I have are crap. The ride is bouncy and jiggly over anything but the smoothest roads.
What’s everyone replacing them with? Specifically looking at alternate sizes which fit the oem rims and don’t rub.
Old Dec 15, 2019 | 08:30 PM
MercOne1's Avatar
2020 GLC43 | 2020 GLE350 | 2014 E350 (sold)
I’m also curious about this. I couldn’t find any replacement options...
Old Dec 15, 2019 | 08:46 PM
rinukon's Avatar
GLC 43 AMG
Research!
Did some research today.
Most likely going to be downsizing tire width to get some decent options.
  • Front: 245/45ZR20
  • Rear: 275/40ZR20
Found michelin pilot A/S 3 plus for this size.
https://www.tirerack.com/tires/tires...3PLXL&i3_Qty=2
Tire size calculator shows less than 1% variation from stock for these sizes. Also have had good experience with the michelins on a previous car.
Old Dec 16, 2019 | 03:30 AM
ppodell's Avatar
2014 Acura MDX
A good deal: https://washingtondc.craigslist.org/...026650102.html
Old Dec 16, 2019 | 12:41 PM
rinukon's Avatar
GLC 43 AMG
Originally Posted by ppodell
Summer tires plus I live on the other side of the country
Old Dec 16, 2019 | 08:36 PM
Mr. J's Avatar
C450, GLC43
  • Front: 245/45ZR20
  • Rear: 275/40ZR20
If you increase the rear width by 10mm both Conti DWS06 and Pirelli Scorpions will fit. I'm switching my front tires out for the Conti DW06 I'll do the rears as 295/40 20 when they wear down further. I like the AS3+ and I run them on my C450, but I'd rather have the wider meats on my GLC.
Old Dec 16, 2019 | 09:07 PM
rinukon's Avatar
GLC 43 AMG
The 295 seems to be beyond the of the glc43 rear rim size. (9.5)
  • Rim Width Range:10-11.5"
Old Jan 1, 2020 | 06:03 PM
marblized2's Avatar
GLC 43
  • Front: 245/45ZR20
  • Rear: 275/40ZR20
would you consider going to a smaller aspect? like 285/35 rear and 255/40 front?
Old Jan 1, 2020 | 10:20 PM
Mr. J's Avatar
C450, GLC43
Ran it by my tire and wheel guy, he was unconcerned about the extra width on the rear wheels.
Old Feb 19, 2020 | 10:09 AM
fl13dl1c3's Avatar
2017 GLC 43 AMG
Have you switched your rears to 295/40/20? If so, any issues or does it work out fine?
Old Feb 19, 2020 | 10:19 PM
Mr. J's Avatar
C450, GLC43
I haven't swapped the rears out yet because they are still at about 75%. My wheel and tire guy checked out the match of outside diameter between the new Contis and the existing rears and the sizing for the new rear contis for when I eventually swap them out. He was completely unconcerned about the extra width on the wheel. He had no concerns about performance or wheel fit. His only concern was that different manufacturers have different tolerances for their outside diameter and he wanted to ensure that OD closely matched between front and rear wheels. It turns out, the sizing for the Conti combo is actually closer to a matching front/back OD than the stock sizes are. Changing just the fronts brought this ratio slightly closer as well. Big differences between front and rear OD can cause fits with traction and stability control. Since these cars use a lot of active braking when tc kicks in, tc can bog down the vehicle and may cause it to eat brakes pretty quickly.
