Drift Mode?
Just a pipe dream maybe :-) figured I'd ask.
"Power to the pavement, precision in the moment
- AMG Performance 4MATIC turns torque into traction and agility. The GLC 43's 31:69 rear bias quickens takeoffs and clings to corners. Variable-torque 4MATIC+ in the GLC 63 and GLC 63 S can send up to 100% of the engine's torque to the rear axle . "
- AMG Performance 4MATIC turns torque into traction and agility. The GLC 43's 31:69 rear bias quickens takeoffs and clings to corners. Variable-torque 4MATIC+ in the GLC 63 and GLC 63 S can send up to 100% of the engine's torque to the rear axle . "Trending Topics
PS: I'm pleased with the performance of my 31:69 torque split AMG C43, but I'm considering an AMG GLC 63 before the V8's go away!
Now the clutch that transfers power/torque to the front wheels can be engaged in milliseconds. These are multi-plate clutches that are operated hydraulically with very high pressures, so they can go from fully open to fully engaged in milliseconds. The same technology is used in the electronic locking differential, which can adjust the locking ratio multiple times a second based on traction needs etc. However, there's again marketing speak with being able to send 100% to the front with 4MATIC+. That also needs to be explained more to understand. At maximum the clutch can fully close and effectively lock the rear axle to the front axle. That's equivalent to a center diff lock. In that case you have a 50:50 torque split. So a full clutch lockup can only send 50% to the front, The remaining 50% can only be achieved based on traction again as described in my post above. Once the clutch is fully engaged (50:50 split) and the rear wheels have zero traction, only then will the front wheels receive 100% of the torque/power. That is different from the 100% it can send to the rear, because it can decouple the front axle, so true 100% is forced to the rear regardless of traction.
I can confirm it makes the car behave in a “RWD only” mode. For anybody wants to do donuts or have more fun in the snow, this is the way to do it. Of course all your baby sitters are turned off and you better know what you’re doing, but it’s RWD only. And if the fronts doing anything, I didn’t notice.
