Wireless Carplay/Airplay for 2019 GLC or below
#51
Yes, I've chosen the right port. Like I said, music apps within Carplay work fine. I'm really confused about connecting wired instead of wirelessly. When I plug my iPhone into the USB port that goes to the box, do I have to do anything to get to Carplay? Should I disable Bluetooth so it doesn't connect through the Bluetooth, and uses the wired connection instead? I'm using an iPhone 13 Pro Max.
Side note, does anyone have the issue with going from Park to Drive and the front camera not turning on? Mine only does it if I go into reverse first and then drive.
Nino
#52
If I remember correctly the 3.5mm adapter has one end that plugs into the USB port of the car, the other end you connect the 3.5mm cable to it. I have the USB cable connect to my USB cable interface #1 of the car. If I disconnect it the sound via wireless CarPlay stops.
I have selected media interface #1 within the Mercedes-Benz interface and sound plays.
As far as wired vs wireless, if you have wireless CarPlay turned in it will connect to your phone that way first. If you connect the USB cable afterwards it will just charge, no data to the module. If you want to always connect with the USB cable then you need to either turn off wireless CarPlay, not pair the phone to the CarPlay module, or turn off Bluetooth after you connect the USB cable to dump the wireless connection and the system to fallback to the USB connection.
#53
#54
You don't have to do anything if your phone is within Bluetooth range when you start the vehicle. Once I start my vehicle the Mercedes-Benz interface loads and a few seconds later the CarPlay module loads, I briefly see its menu followed by the CarPlay interface. If I switch back into anything Mercedes-Benz, such as navigation or the vehicle settings I must press and hold the favorites button until it switches back to the CarPlay interface.
If you chose to use the USB cable instead of wireless CarPlay I would suggest you not pair the phone to the CarPlay module and instead plug the phone to the USB cable after starting the car.
#55
#56
Check Settings > General > CarPlay (select the applicable "car") and toggle on; you also have to enable Siri in the Settings menu.
The Star/Favorites button you have to press if you exit the CarPlay interface and enter the Mercedes-Benz interface, that is how you get back to it (CarPlay).
#57
Are you trying to use wireless or wired? There are some settings you will have to check on your iPhone.
#58
Yes, I'm trying to use Carplay wirelessly. I just checked my Carplay settings on my iPhone, and the only "car" in there is called ICar. Is that what the unit should show up as? The Siri setting you are referring to is on my iPhone, or in the Carplay settings? Thank you so much for trying to help me out.
#60
i also have Burmester audio system and mine connects automatically. I’m running out of possible solutions, PM me.
#64
I can't speak for the dealer, but I will tell you that my service advisor knows it's there and he hasn't warned me about anything. I imagine it could, maybe, perhaps be an issue if ever there is a problem with for example the audio system since you have to mess with it, but they have a guy that will install them (3rd party CarPlay modules) for their customers he said.
#68
@LenniePaz It happens to me sometimes, but I have noticed that it is after a few unsuccessful attempts between the phone and CarPlay module. For example, if I start the car and the phone is not nearby after several times of doing that iOS will display the same message you posted. As long as the phone is near (within Bluetooth range, or inside the car) when the system starts up I have no issues.
#70
#72
When I'm using Google Maps and SiriusXM in Carplay, the voice directions are much lower than the music volume when the directions are spoken. Is there a way to set the voice directions to their own volume that stays the same no matter what the volume is set to for SiriusXM? I can't seem to accomplish that.
#73
#74
When you say "Alter Volume", you mean adjust one of the volumes in there, correct? Or is there a setting called "Alter Volume"? Also, I'm confused how those volume settings work. If I adjust the Voice volume, should the volume stay the same in Google Maps? I was hoping that's how it works, but as I turn up the volume on the radio, Google Maps directions get louder too. Carplay in my work van works like this: when I set the volume for Voice,lets say 10, the volume stays at that level no matter what. If I'm listening to music and using Google Maps at the same time, and I turn the music up, the voice in Google Maps stays at 10 all the time.
