Wireless Carplay/Airplay for 2019 GLC or below
This is an install and review of Road Top’s device decoder box that adds Carplay or Android Auto or Mirror Link, plus other features. This product is for your Mercedes Benz 2015 to 2019 C, GLC, CLA, GLA with NTG 5.0+ interface that did not have Carplay or Android Auto capability from the factory. Depending on your factory options, you either have the infotainment system that has the smaller screen or the upgraded (Command) system with factory navigation and biggerscreen that does not have Carplay capability.
I bought this just 3 days ago via amazon I decided to put together this tutorial to help others who are intimidated by the install which really is not difficult.
So what are the benefits of this device. Besides the obvious of adding Carplay, Android Auto or Mirrorlink wirelessly or via wired USB. It works with your usual factory controls including steering controls You also retain the factory interfac. All you have to do is click the button with the star symbol to switch from original and to the new one and vice versa.
What I have is a 2019 GLC63 Mercedes Benz with command with no Carplay from factory. So all my install information is base from my car. But it should be very similar towards all different Mercedes models mentioned above. Along with the manual that comes with the product and from the seller. There are plenty of Youtube videos that will help you with the install. So treat this as a supplement to other information.
The following 5 users liked this post by izzyAMG:
1SickGLC (03-10-2021),
Chrisk03 (11-27-2020),
CPD SLK (12-07-2020),
Igor Grunskiy (12-04-2020),
tedboss1 (11-30-2020)
Thanks for the detailed instruction.
Can you use the Carplay navigation like Waze and in the same time listen to the car radio?
I had a similar system on my Macan and I couldn't.
Do you mean tune native AM/FM radio while running Waze? Wow that’s a great question because I’ve never tried that because I just listen to music apps all the time. But I tried it just now and it actually does it. I tuned in an FM radio channel. Then I pushed and hold the star button and it switched me to CarPlay and I went to Waze while listening at the car radio. Now to listen back to a CarPlay music app. You have to push hold star again go back to radio and switch it to USB interface then go back to CarPlay and play music from an app.
You are probably right, I guess you just can't have everything. One solution is to grab a radio app like TuneIN or Iheart.
@izzyAMG what do you mean to transfer the audio cable in step #14... I don’t have any audio
I found it little after I sent the message after studying the installation pictures you posted and the harness itself, thanks for the help! It all works now, hopefully no issues in the future.
How long have you had yours working?
I just installed mine as well but I've seen others who had there's for a while with no issues. Yah hopefully all should be okay.
Regis (12-02-2020)
It came out of frustration not having CarPlay option from factory for an expensive car. And now finally having one I can live with I wanted to share so everyone don’t get intimidated installing it.
The following 3 users liked this post by izzyAMG:
Amazing tutorial, thanks for caring to share!
My only question though, will it negate the warranty? Or if being removed prior to a dealership visit it leaves no traces so we should be golden?
Cherylpg (06-20-2022)
He claimed MB will not make it an issue because it is an external device from the head unit and that you are not hacking the internals but just bridging a device. Not the same as like replacing the whole display unit. He claims he had plenty of clients do this and was never an issue. Obviously if you made a mistake and broke something during the install I doubt MB will cover. And I don’t think pulling it prior to going the dealer makes sense. It’s just not that easy to do.
Now I’m just going with what my SA told me. So it can still be an issue. But I’ve not known MB to give clients a hard time. Its not like we have an option to get the CarPlay from MB. It might also help having a good relationship with your SA.
Wish there wasn’t such a big difference in volume level from the CarPlay to regular radio, even after adjusting the volume level within the decoder, but all in all I’m happy with it.
Followed your instructions and got everything successfully installed - thanks a lot once again! Left the usb cable unplugged as wanted to keep it minimalistic and without it it works like a charm. Had to restart the unit as it was only showing the settings menu at first, now it works over WiFi seamlessly and couldn’t be more happy about my car having modern phone integration!
I’ve noticed that sound quality is different compared with my Bluetooth and has much more bass, had to adjust in EQ.
One question that I’m struggling with now - how do I get back into the box settings (black and white one)?
Igor Grunskiy (12-07-2020)
Just received the decoder from Hongkong. Very quick delivery.
Two questions before I start install.
Do I need to disconnect the battery prior to installation?
By the way, where is the battery located in 2019 GLC63S ?
I didn't disconnect mine, but if you want to be safe best to do so.
It’s back right in the engine bay (as you look at it) but I didn’t disconnect either
I have installed mine and it seems to work with Android auto.
When I'm navigating using Waze I don't get any audio instructions.
Also when I try to play iHeart radio I don't get any sound but I can see that the app is playing.
Can anybody help me with this?
Do you have any sound at all?
