Acceleration "dead spot" - AMG GLC 43 coupe
https://www.nhtsa.gov/report-a-safet...le-information
After having a GLB loaner for a month with all of those “assistance features”, I was happy I do not have them on my regular vehicle and I nearly got into trouble no less than four times. Two examples:
The rear cross traffic alert applied the brakes when nothing was around me (not even ghosts).
It did it again when it thought I was too close to an oncoming car when the car was at least one tractor-trailer away from me.
As to your last comment, you can never do enough damage to Mercedes to stop anyone from buying them, as they make excellent cars.
MB local dealer where I got the car provided no answers or solutions. Of all the damn ironies, coming back from that dealer after the most recent service appointment, I had to slow down due to a car in my lane waiting to turn left, then tried to gun it to get into the next lane over, and...nothing, just no response. That time I actually aborted the lane change before the acceleration kicked in.
It doesn't do this in any other set of circumstances, not from a dead stop, not when I accelerate quickly after coasting downward to 20 mph (for example). I wonder if anyone else has experienced this or has thoughts? Thank you!
To me that's not an adequate response, that they all have the same problem. What he did explain was that in comfort mode and in second gear, which is typically the gear it will be in under that circumstance, is that the transmission is working out which gear to be in.
Personally I think it's a flaw. For a car worth $140k AUD and with all the alleged engineering that goes into these cars MB have clearly missed this one. It should not lag like it does, and as you say, it's dangerous.
We bought ours new and only after a couple of drives noticed the problem, has always been there when I drive it. To avoid it I need to feather the throttle on but still need to be careful when pulling out on busy roads.
I will follow this up with the MB dealer and see if I can get them to do something.
Cheers
I went back to all the places where this happened consistently and sure enough a manhole cover was in my path each time. It's stupid that it took this long to discover and to fix. Trying to make a care safer can often have the opposite effect.
Wondering if any of you have knowledge of whether the 2023 AMG GLC 43 coupe also has this acceleration lag issue or it was corrected?
Also wondering if the 2023 can take anything other than summer tires (the other major problem I have with my 2020 model).
Thanks!
Thanks!
link between regular dealerships and head office engineer teams is bad or broken altogether. The only way to make em move is a bad pr \ publicity and we cant get to be annoying enough with this forum. I wonder if we can ever
may have any real connection to some engineer like many PC hardware companies do on their forums where dev team work with end users on logging troubleshooting and rolling out fixes with updates.
Have exact same darn lag as described with glc63 as well and its bad and its not a turbo lag but a calibration \ tuning problem.
