Assistance Graphic
Old Nov 27, 2024 | 08:41 PM
Tech-Ed's Avatar
Assistance Graphic
  1. This doesn't seem to do anything. Does this do anything other than show a fake hood image?
Old Nov 27, 2024 | 09:03 PM
W205C43PFL's Avatar
Yes, if you have DISTRONIC, it will show you another vehicle in front... an W222 S-Class the closer you are to it the closer it will appear in front of the hood.
Old Nov 27, 2024 | 09:05 PM
W205C43PFL's Avatar
Another thing I forgot is if you have Lane Keep Assist, it might show the vehicle drifting to one side and a red line on which side when it does.
Old Nov 28, 2024 | 12:54 AM
superswiss's Avatar
2019 C63CS
Old Nov 28, 2024 | 06:41 AM
W205C43PFL's Avatar
Come to think of it, OP might not have DISTRONIC since there is no distance displayed as from what I am understanding from the operator's manual, the distance shows despite DISTRONIC is off as long as it is equipped.
Or does distance only show when there is a vehicle detected in front?
Old Nov 28, 2024 | 01:08 PM
superswiss's Avatar
2019 C63CS
I never really use the assistance display, so I don't recall. But what I posted doesn't say what it looks like when DISTRONIC is off. DISTRONIC has three states. Off, Deactivated and Activated. DISTRONIC has to be turned on first, and then it goes into the deactivated state until you activate it, then if you cancel it goes back to deactivated. There's an On/Off button for DISTRONIC on the steering wheel, or with the old style stalk I believe you have to move the stalk to the On position.
Old Nov 28, 2024 | 01:35 PM
W205C43PFL's Avatar
I see, will need to find out another way. Or if OP comes back and confirm if the vehicle is equipped with DISTRONIC or not.
Old Nov 28, 2024 | 01:44 PM
superswiss's Avatar
2019 C63CS
Here's some more info about what it all displays. It's not just DISTRONIC. OP should probably read the owner's manual first. This stuff is all explained in there after all.
Old Nov 28, 2024 | 01:48 PM
W205C43PFL's Avatar
https://cimg5.ibsrv.net/gimg/www.mbw...de89d258e3.jpg
https://cimg6.ibsrv.net/gimg/www.mbw...d9a7ec4f96.jpg
Good list.
Old Nov 28, 2024 | 02:21 PM
superswiss's Avatar
2019 C63CS
But to your point, what it ultimately displays depends on the car's equipment. In newer models it also visualizes the active lane changes as shown below. But if the particular car isn't equipped with the driver assistance package, then this display is of limited use.
Old Nov 28, 2024 | 02:24 PM
W205C43PFL's Avatar
I thought so, the facelift W205 system is more sophisticated.
Old Nov 30, 2024 | 10:51 AM
Tech-Ed's Avatar
I have no idea if Distronic is on this vehicle. I cannot find anything about activating it in any of the menus so I'm assuming that it isn't part of this car, also considering that the vehicle doesn't have adaptive cruise control either.
Old Nov 30, 2024 | 11:25 AM
W205C43PFL's Avatar
Don't worry about that, it is easy to determine that. If the MB logo in the front is completely flat (not 3D) then it has DISTRONIC.
Old Nov 30, 2024 | 02:13 PM
superswiss's Avatar
2019 C63CS
Also it's not activated via any menus. It's activated with the cruise control stalk on the left of the steering wheel. Also, type in the VIN at the link below. It'll decode it and give you all the options this car has.
https://mb.vin/
