GLE accessories
"I reached out to Atlanta yesterday and they’re hoping for availability on the retrofit piece by some time in August but haven’t gotten a firm date yet. This is a top priority for us so we will let you know if anything changes. Thank you so much for reaching out! Hope you have a great week…"
All the Best,
Jill Martinette
Accessories Development Manager
Western Region - Mercedes-Benz USA
All the Best,
Jill Martinette
If anyone comes across anything let me know.
I do not like the stock North American plate mount, which is a chunky plastic thing stuck in the middle of the front fascia that requires holes to be drilled in it. It also disrupts one of the main character lines on the front of the car. I had used the Sto n Sho mount on my M4 previously and liked it. It is a design that allows the plate to be installed or removed in about 5 seconds bu pulling a spring-loaded pin on the bracket, and it floats the plate free of the front of the car. Caveat: They do not yet have an application for the 2020 GLE with AMG Line, so I adapted one from the 2019, which is not perfect but works, IMO. I backed the plate itself with a carbon fiber sheet for more rigidity and blind riveted the whole thing together. I had to shim the bracket because of the curved nature of the bottom valance. It looks low to the ground in these photos because I have the suspension in the lowest position and the driveway is sloping up. Let me know what you think.
Sto n Sho
#167-890-30-00 BASIC CARRIER ~$320. Max. load = 100kg - 6.5kg (weight of bars) = 93.5kg (206 lb)
I’m not thrilled by the direction MB has the plug pointed almost straight down.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
There are two reasons to get them. My wife wanted them to help with entry and exit. I also found that without them there seems to be a lot of dirt and mud on the stepped portion of the lower panel of the entry. Nothing gets in the car but every time I wash I have to clean each (below door) ridge. Hoping the steps will reduce that mess.
i also purchased the low wall Mercedes cargo mat and a set of wheel locks. I was given 15% off without asking, a pleasant surprise. The Mat is very nice and matches the interior floor mats that I was given at purchase.
The 15mm stud guide bolt is currently unavailable and back ordered.
