With standard steel suspension there is a huge gap from .......
So, are my only options to go with 21 inch wheels?
Check out this post:
https://mbworld.org/forums/gle-class...ml#post7762254
You appear to be missing the front wheel arch moldings. Also 20 & 21 Mercedes wheels have tires with less section height as the wheel size increases to keep the diameter the same. So going to a 20 or 21 would only gain about an inch total or half of that on top and each side if my info is correct. Wheel molding will get you more for less $ and you could remove rear and have them painted as an option.
https://mbworld.org/forums/gle-class...-question.html
