Spoke too soon...I知 disabled in daughters driveway
2023 GLC 300 4MATIC
Came over and visited for a while went out to the car to start it and nothing happened and the lights are flashing. My ABS flashing a light that the vehicle is in operable and parking vehicle is in operable. My lights will not turn off nothing happens when I push the start button.
Supposedly a technician is on his way. I asked this lady thinks some kind of sensor is confused if I could just disconnect the battery and then reconnected everything would be OK we shall see
2023 GLC 300 4MATIC
Tech has been in my car for almost an hour. Looks like he is about taking out the passenger seat to get to the battery. This is Ridiculous. Lights have been on for two and a half hours now.
2023 GLC 300 4MATIC
He disconnected the battery, waited a few minutes and then reconnected. The system reset and everything went back to normal. There should be some kind of disconnect or reset button vs. going through this.
the Mercedes connect guy tried to tell me my ABS or braking system wasn’t working therefore the system shut down to keep me from driving. He was only reading from the manual. I told him no I’m sure it’s a sensor miscommunication and everything is locked on...headlights won’t shut off.etc...it won’t turn off until the power source is cut off.
It is 90 degrees. Would be horrible if it was me and my little grandkids stranded out on the highway. Luckily was in my daughters driveway and I stayed inside in the a/c.
Now I’m concerned this will happen again and again.........
Received 1,182 Likes
2020 GLE 450; 2023 BMW M2 Coupe
Failure to restart
the Mercedes connect guy tried to tell me my ABS or braking system wasn稚 working therefore the system shut down to keep me from driving. He was only reading from the manual. I told him no I知 sure it痴 a sensor miscommunication and everything is locked on...headlights won稚 shut off.etc...it won稚 turn off until the power source is cut off.
Now I知 concerned this will happen again and again.........
2023 GLC 300 4MATIC
Yes our situations were very similar in that I had all those same error messages. But my headlights would not turn off. There definitely should be some type of electrical restart button just like when you have to shut down your phone or iPad every once in a while to let things clear out.
Reboot
Maybe it does and we're not aware of it? You could always install a battery disconnect switch to the negative terminal of the battery, but if you need to go to the trouble of lifting the seat to access it it's almost as easy just to pull the terminal. I'm going to start carrying the appropriate wrench.
guitarplayer (07-11-2019)
On my current vehicle they advise that you disconnect both terminals and touch the two wires together to perform full reset.
Had to do that twice so far over the course of 5 years in order to reset whatever unit was causing problems at the time.
