GLE 580
Old 01-12-2021 | 05:49 PM
  #201
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
Originally Posted by mikapen
Actually the perforations are to provide a path for gasses generated by out-gassing from the pads under extreme heat. Without the perforations or grooves, the gas that's generated lifts the puck from the disc, just like black ice under tires.
And to another post, the perforations are cast in, not drilled. This decreases the possibility of stress risers after drilling.
The gas was new to me so I was forced to get educated rather than “shoot from the hip” like I’m known to do...
Heat and gas are both right but Brembo lists 5 reasons and they describe a drilled disc, not sure if that’s really cast or drilled.I learned something thanks M....Here’s Brembo’s take-
1) More grip
Compared to a standard disc, from the initial braking phase, Brembo Xtra drilled discs ensure greater grip and more responsive and efficient performance of the braking system. Because of the holes, the friction coefficient between disc and pad is greater. Especially in the initial phase of braking, you can notice a quicker and more decisive response when you press the brake pedal.
2) Attractive and sporty look
A visual impression is also important and a vehicle with Brembo Xtra drilled discs definitely does not go unnoticed.
These discs are attention grabbers and are guaranteed to increase the sporty aesthetic of the vehicle.
If a sports car stands out primarily because of the details, then in order to give your car more of a “racing” touch, nothing is better than the enhanced look that Brembo Xtra drilled discs ensure.
3) Advantages on wet roads
The holes disrupt the layer of water that can cover the braking surface. That layer of water acts as a cushion on standard discs, separating the disc and brake pad and increasing the time it takes to stop in wet conditions. Brembo Xtra, on the other hand, provides an efficient response from the very first time the brake pedal is pressed, no matter what the weather conditions are.
4) Better heat and gas dispersion
​On a standard disc, a sequence of decisive braking manoeuvres in a short period of time translates into a temperature increase. The combustion of the resins that make up the pads, in turn generates gases (fading) that act as a bearing between pad and disc, decreasing the efficiency of the braking system. On a Brembo Xtra disc, on the other hand, the holes allow for quick expulsion of these gases, keeping the friction coefficient unaltered. The holes also help heat from the braking system dissipate more efficiently, even in normal driving conditions.
5) Pad always in top shape
On a standard disc, wear can result in a build-up of ferrous material, which is deposited on the brake pad's friction material.
The holes on Brembo Xtra discs, on the other hand, have a scraping effect, which cleans the surface of the brake pad, freeing it form materials that can dampen the brake's response.
There is such a thing as love at first sight, and it often takes the shape of a Brembo Xtra drilled disc.
Old 01-12-2021 | 05:55 PM
  #202
ENCT's Avatar
2021 GLE580, 2022 BMW X5, 2022 911GTS Incoming
I have only seen them referred to as drilled. Never heard them refer to as perforated or cast hole rotors. Regardless of how they are made the early 580 do not have them. I think my wife will be fine with the rotors supplied. Now on my E63S I would like the cast hole rotors in ceramic composite please.
Old 01-12-2021 | 06:21 PM
  #203
Ron.s's Avatar
I can’t tell for certain but my rotors are drilled to chamfer the hole. They may be cast and then drilled to clean them up. Here’s what I found on the net.
Drilled rotors are produced in many different ways. The process to make a fine quality rotor is substantially different than what is used to make a poor quality specimen, and examples of each will be presented in this article.
Even though there are many different patterns of drilled brake rotors, what is important to focus on is the drill hole integrity. A ceramic drilled brake rotor can actually be cast at the factory as to eliminate drilling imperfections, but drilled rotor designs can still be created properly after casting with fine tools in cast iron as well.
Any imperfections in a brake rotor is subject to cracking when the brake rotor heats up and cools, so these drilled holes at the very least must be created with precision when added post-casting. When a brake rotor is drilled out manually, it often leaves the holes brittle at the edges. If you had a microscope, you could view these drilled edges to verify this. After the drill pattern is embedded in the brake rotor, the factory must use a special milling machine to file these edges down to be as smooth as possible.
Source 2
If the manufacturer goes one step further to prevent these cracks, they will put on a special chamferingor edging on the drill holes to reduce wear points. Some manufactures simply use countersunk or radius edging to do this, however sinusoidal edging minimizes the stress points to a maximum level.
Sinusodial Camfering
Old 01-12-2021 | 07:15 PM
  #204
mikapen's Avatar
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
When I get time, I'll look for the reference on cast perforations. I'm pretty sure it was on the Daimler site.
Old 01-14-2021 | 02:41 PM
  #205
BACnMercedes's Avatar
19 E63s(wifeys) & a 21 GLE580
Well, well, well. I think mine finally showed up on my dealers website..........unless they have two comparable builds.
Old 01-14-2021 | 04:06 PM
  #206
ENCT's Avatar
Should be any day now.
Old 01-14-2021 | 05:31 PM
  #207
mikapen's Avatar
Another supply story - I shopped at LazyBoy yesterday. Their special order furniture was just extended to 9 months out (getting worse). And my friend the Custom Home Audio/Security guy has just shut down completely because components are stuck on containers.
And did you know that OSB is now $27 per sheet?
Pandemics are definitely disputers.
I wonder when my Feb build will actually arrive.
The good thing is - I am starting to enjoy my old OBD1 go-to-the lumber yard pickup again.
And maybe I'll miss the need for winter tires for the 53!
Old 01-14-2021 | 05:36 PM
  #208
I am now hoping I can stall my tag transfer about 2-3 weeks and therefore pay the taxes on my old GLE and then register my new car. That will probably save me about $600-700.
mikapen (01-14-2021)
Old 01-14-2021 | 06:13 PM
  #209
Ron.s's Avatar
See, out of the rubble grows a rose. Also you might not need AS tires this year. Here they adjust fees during the transfer of registration, you are lucky.
Old 01-15-2021 | 08:37 AM
  #210
TempeAndy's Avatar
'21 GLE 580, '20 Cayenne Turbo
Got word from my SA yesterday on our 580 order (Jan. 13 was the replanned build date, not sure what actual was):
"your vehicle is at the VPC (vehicle processing center) Long Beach California. We expect arrival at the dealership in two weeks"
Old 01-15-2021 | 08:48 AM
  #211
nsoltz's Avatar
2023 EQB300
Hope you see your car soon. I was under the impression that Vance VPC did the prep and transported from there.
Old 01-15-2021 | 08:58 AM
  #212
Ron.s's Avatar
I think that’s right except for some overseas shipments, maybe W. Canada. Mine showed the Long Beach VPC but traveled from Vance by train to Salt Lake & then by truck.
Old 01-15-2021 | 09:00 AM
  #213
nsoltz's Avatar
2023 EQB300
My friend in CA has a GLB on order and it will go via ship from Mexico to Long Beach VPC and then to Palm Springs.
My 350 definitely showed Vance VPC.
Old 01-15-2021 | 09:50 AM
  #214
It.................Has..................Arrived!
The following 3 users liked this post by BACnMercedes:
GregW / Oregon (01-15-2021), Ron.s (01-15-2021), Vegas Benz (01-15-2021)
Old 01-15-2021 | 05:55 PM
  #215
ENCT's Avatar
When are you picking it up?
Old 01-15-2021 | 07:40 PM
  #216
We are going to drive the Audi first in the morning, then the 580 and make a finally decision. I’m still waiting to hear back on a few details of the deal too.
Old 01-16-2021 | 02:58 PM
  #217
Well today was a disappointing day. The 580 is on hold to see if they can fix the crappy leather.
Also, what pattern does your 580 have on the leather? I don’t remember a pebble look on the out side areas of the seats. What does it look like some of the others that have 2020s and 2021s?
Old 01-16-2021 | 07:06 PM
  #218
ENCT's Avatar
We ordered the exclusive Nappa, the seats are smooth leather. My son has the standard leather which does have a pebble look. It shows up well in the configurator. I suppose you didn't like the Audi?
Old 01-16-2021 | 08:07 PM
  #219
Ron.s's Avatar
They won’t commit to new seats? Seems like a no brainer but there’s no guarantee the new ones will be better. I guess it’s prudent to get approval from Mercedes. I haven’t seen bad seats before...how were the Audi seats?
It must be hell at the plant right now...seats-batteries-seat belts-chips & who knows what else.
Old 01-16-2021 | 08:52 PM
  #220
The Audi was very nice And is a great contender. It really was a hard decision with the MB just being a lot better at tech stuff in the car and a slight comfort advantage.
They are going to send the car to a local shop to see what they can do first with the seats. They really don’t have anyone at the service center to fix leather.
Fingers crossed.
Old 01-16-2021 | 08:56 PM
  #221
Ron.s's Avatar
Any pics? Do yours have a recessed area where you sit? Several brs9de mine had a depression right where the butt sits. My 450 didn’t. Looks like it might encourage stretching in that area.
Old 01-16-2021 | 09:46 PM
  #222
No pics. I was so dumbfounded and pissed today that I forgot to take any.
I found this picture in the GLS section of a new 580 and I thought it had small problems too but not near as bad. I circled the small looking problems in red on this car and then the problem areas of the 580 I ordered in yellow (Remember the GLE has a center seat). The red areas do not look that bad but what was on mine looked worse. Mine were wrinkles like Ron.s showed on his 53. I even had a few areas on the front seats as well.
Old 01-17-2021 | 09:28 AM
  #223
places's Avatar
No more MB:(
More GLE issues. They really seem to be having issues with the leather.
Old 01-17-2021 | 10:12 AM
  #224
ENCT's Avatar
Mine has a few minor areas I suppose could be a bit better. I find the older I get the less I look for imperfections. All in all I am happy with the fit and finish. Shame to say that spending $100,000 on a car does not mean much these days.
Old 01-17-2021 | 11:53 AM
  #225
And that’s the problem I have.
I’m going to be really mean here and state this. The SQ7 didn’t have any visual problems that I noticed. We also looked at the interior of a new E and S class yesterday and the leather looked great. So, is it a supplier issue? Plant/Assembly location issue? Or just a quality control person issue at the end?
Am I pissed? Yes. Do I still want the 580? Yes. But we will see what happens.
Quick Reply: GLE 580
