Winter Tires - What are you wearing?
On that note, I'm assuming there is a lift point in front between the wheels. Took a quick look and it looks like it's a finished area, but didn't get a good look. Figured I'd use the rear diff in back.
‘I don’t know if the drawing is the way you measured but I think you measure the shank from the top on a tapered bolt vs under like you show on a normal flat headed one. There is a significant difference on a conical vs ball shape because of the longer taper on conical. That’s why I ordered the bolt with a 33mm shank comparing the tire rack bolt to the factory one.
Edit-I mean from the top of the taper.
‘When the taper goes in a counter sunk hole it should be measured as in the pic, IMO. If not you are understating the ‘reach” when comparing to square vs ball vs conical. Semantics aside this is the only accurate way to compare lengths.
Stock Mercedes-48mm top of taper-3mm of ball taper
Otis Black-42mm top with 9mm of cone taper-shank 33mm
Tire Rack Silver-37mm with 9mm of cone taper-effective shank (-1mm) 28mm
These numbers should be close enough for making a decision on what will work best with your winter setup.
The wheel manufacturer suggested I get the 28 mm (when I presented him the options of 28 and 33)
Just finalizing that order now before I figure out the bolt situation.
I wound up lifting the car at the jack points on the side, could not locate a lift point in the front of the car. No big deal, easy job.
Greg, I used 2 of the stainless steel lug bolt guides you posted, they are an excellent addition to the process. Those 21" wheels are heavy
But I continue to have a brain cramp with offsets and miscalculated the positioning that 8 1/2” wheels with et45 would have on the front tire location. There was no noticeable difference in the upper tread and tire bulge location from stock 9” wheels with tires the same size as stock. These are very large tires and sucking in the bead does not make them narrower. If there is any difference it is very negligible.
Now on offsets....less offset moves the outside Wheel edge out-not in. The offset is from center and I know better but continue to get it wrong until thinking about it. This came up early in the thread and is the reason I didn’t buy Titanium extended length bolts and spacers. Promptly forgot!
So I’m glad I went with et45 instead of using my et32’s. I measured from the widest point of tire bulge before and after using a level along the wheel trim. This is not exact but close enough for my purposes. My new tire at the widest bulge moved out beyond the trim more than 1/4” - they were just about 1/16 inside with factory tires and wheels. The tread is still inside the fender.
The net change shouldn’t cause any rubbing but will slightly increase mud and debris on the body. I found some mud flaps for the 167 GLE with AMG, shipping from China 3 weeks out. I’ll post pics and fitment when they arrive. They are small and won’t offer much protection (if they fit).
Anyone considering spacers might want to double check their wheel offset and calculations.
Here are a couple of pics.
- 275/50R20 113S
- 255/55R20 107T
My 20" rims cleared without issue (thanks to Ron for confirming that before I installed)
