Jack stands
Old Nov 10, 2019 | 12:48 PM
tommyr's Avatar
25 GLE53, 24 Macan, 15 GLK350
Jack stands
I'm going to change over my own tires/rims for winter, and just got a pair of floor jack stands. I've changed plenty of tires in my day, but having jack stands is new to me (I'm using a floor jack, but with such a heavy vehicle and tire setup the stands seem essential). I believe that I should I lift the car at the jack point on the frame, but if I do that, is there a specific spot to put the jack stand(s)??
Old Nov 10, 2019 | 12:58 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Use of jack stands
I usually put them under the suspension A-arm pivot points, which are quite stout.
Old Nov 10, 2019 | 09:18 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
As I recall the manual points out a jacking point and a recommenced place for a jack stand.
Old Nov 10, 2019 | 09:48 PM
tommyr's Avatar
Ron, manual, really? That thing is way too big. There must be a PDF available somewhere...
Old Nov 10, 2019 | 09:59 PM
Jack stands
Jacking points are described, but no mention of jack stands. The scissor-type jack supplied with the vehicle is less likely to have catastrophic failure than a hydraulic jack. However if you are lifting a whole end of the car you will need to bear weight on at least one stand. The front & rear subframe members are the obvious locations. I found you can lift a whole side of the car from just the rear jacking point if you have a floor jack with enough lift.
Old Nov 10, 2019 | 10:00 PM
Ron.s's Avatar
�� No argument on size and difficulty but....
There is a PDF previously posted but as I recall it may not be searchable but a little easier to use.
Old Nov 10, 2019 | 10:06 PM
Owner's Manual PDF
The high-res one can be downloaded from here. It is searchable, but I've bookmarked mine, as well.
https://www.mbusa.com/en/owners/manuals
Old Nov 10, 2019 | 10:25 PM
Ron.s's Avatar
An unused jacking point would be a good place for a Jack Stand. It’s been a long time since I saw the schematics but I thought that there were two at each corner. Might have that wrong but that’s the way I remember it.
Edit: Just checked and only one jacking point on each corner. Audi has 2.
Old Nov 10, 2019 | 11:03 PM
Jack stands
Here's one location when changing a wheel (on my '12 ML).
Old Nov 11, 2019 | 10:35 AM
Henry Stark's Avatar
GLC63S
https://www.reverselogic.us/phone/jack-stands.html
I just use a Jack with this adapter:
https://burgertuning.com/products/me...adapter-by-bms
or even better:
https://www.reverselogic.us/phone/me..._jack_pad.html
Old Nov 11, 2019 | 11:02 AM
Ron.s's Avatar
Another method is to block the jack or use a special jack stand.
I use a 4x4 under the lift point on my floor jack so that it can’t collapse. Not all jacks may be built to make that work.
The other method is a special Jack Stand like this one. You jack up the car & install the stand.
Its not always safe to try to crawl under the car to place a jack stand but that depends on the location.
Old Nov 11, 2019 | 11:28 AM
Jacking (up)
I have one of those for my BMW, but never found a problem with a hunk of 2x4! My old (~40 yrs) American-made Walker jack keeps on going. Not sure you can even buy a US one any more.
