LOWERING CAR WHEN PARKED
Old Nov 27, 2019 | 03:08 PM
MargarittaMB's Avatar
ML 350
I have found the option to lower the car while parked very useful (we often carry an old large dog). I would like this to happen each time the car is in park. Has anyone found if this is possible and if so how?
Old Nov 27, 2019 | 04:10 PM
bad habit's Avatar
A
You should do some searching, this has been extensively discussed
Old Nov 27, 2019 | 05:46 PM
Philamg's Avatar
GLC 450
Not possible, has to be activated each time.
Old Nov 30, 2019 | 11:59 AM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Unfortunately. Not too convenient.
Old Nov 30, 2019 | 02:33 PM
KJ's Avatar
KJ
2020 GLE 53 AMG
It would be better if it lowered every time.
Would make getting in and out easier and the car would also look nicer lowered to it's maximum position.
I guess it's to prevent a situation where a driver parks over a curb and then the car lowers itself on top of the curb after and causes damage to the under body.
The system should give us the option to choose for drivers who are more careful about that and want that feature enabled.
Old Nov 30, 2019 | 04:29 PM
Henry Stark's Avatar
GLC63S
I’m not sure why it wouldn’t have the lean feature from factory but I am sure the folks at RENNtech are developing their suspension module for the new GLE. Once in use you can leave the vehicle at your desired lowered height and it will raise to the oem height once the vehicle reaches about 30 mph and will return below that speed.
Old Nov 30, 2019 | 05:41 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
There are other feature switches that don’t work right, IMO.
My mirror fold on locking keeps resetting to on, lasts about a week when I set to off.
Lane Keep reset to on until a recent coding change.
Driving mode and lower on entry both should stay as set. There is no logical reason for any of these settings to change as the ignition cycles.
Has anyone else noted that ride height changes for no reason? I keep having to change my rear view mirror setting not each drive but frequently. Recently I was at a stoplight I noticed the nose lifting. Had driven about a mile in C with vehicle empty. If there hadn’t been a car in front of me I wouldn’t have noticed. This will be a tough one to show my dealer.
Old Nov 30, 2019 | 09:09 PM
zengshengliu's Avatar
2020 Mercedes GLE 450
I didn't notice ride height change by itself on low speed, but I did encounter the car rise (after turning on auto lowering on exit) for no reason after the car is parked.
Old Dec 1, 2019 | 07:24 AM
Philamg's Avatar
GLC 450
Confused about ride height changing and having to change rear view mirror setting, surely the rear view mirror stays in same position relative to seat setting regardless of ride height, certainly does in mine.
Never had ride height change for no reason, must be another gremlin in your car Ron.
Old Dec 3, 2019 | 09:22 AM
tiri's Avatar
2020 GLE450 4Matic AMG-Line
Happens to me regularly.
Old Dec 3, 2019 | 12:08 PM
Is it possible that you have the car lowered on parked, and it starts to raise when it is above a set speed which "cancel" the lowering car when parked feature? Or does it do it throughout the drive and not just one time?
Old Dec 3, 2019 | 12:09 PM
It cancels.
Old Dec 3, 2019 | 12:14 PM
Originally Posted by GregW / Oregon
It cancels.
I know it does cancel itself
But does the Ron and tiri experiencing related to this process which the car starts to raise when the feature cancel itself?
Old Dec 3, 2019 | 01:21 PM
Philamg's Avatar
GLC 450
Not when stopped.
Old Dec 3, 2019 | 01:39 PM
Not when stopped.
It shouldn't, but mine also does randomly raise itself after parked (engine off)
Old Dec 3, 2019 | 01:42 PM
bad habit's Avatar
A
Yep same here
