Tire Pressure Monitoring (TPMS) individual display is not working as it should
#51
2020 GLS580, 2020 Corvette Z51
It's possible that your Government prohibits the type of TPMS you want. Could you check local statutes and report back?
Or check a friend's current model year car to see if they have the same as you?
Here in the U.S., our Government bans the advanced LED headlights that are available in the EU. To me it's a safety issue, but lobbyists have defeated attempts to allow modern lighting here. Just as Lobbyists in EU banned WDH for years. Maybe there's a hidden Special Interest group in Canada that doesn't want modern TPMS?
#52
Not the case in Canada. Both my cars have TPMS with individual read out. I think if you install the sensors , it should be a software download to make it work. Call MB in Toronto. Someone there should be able to give you an answer or get you an answer. The sensors are approximately $50.00 per wheel.
#53
#54
2024 GMC Canyon Denali..... 2018 Audi SQ5
That is the reason for my post to find out how to do it. Simply adding individual sensors to each wheel and changing the MB computer programming is not enough. I have asked my local London Ontario dealer about this and simple answer is, it is cost prohibitive. The majority of Mercedes dealers in Toronto and area are corporate owned and the official word from Mercedes Canada is that it cannot be done. I read about an individual who moved to the US from Canada and could not import their Mercedes because of this issue. It could be that this is the policy of Mercedes so that some Canadian Models that are cheaper in Canada won't be exported to the US because the US requires different TPMS among other things.
#55
#56
I got the same issue. My GLS580, 2021 model, also does not display the digital number about the 4 tires' pressure. And I went to the dealership services, they told me that in Canada only AMG and Maybach, or S-class have the features. Others are not. They only have the low tire pressure warning ,and you also don't know which tire pressure is low...... so funny....This is a super normal safety feature. I guess only the sensors are different. If anyone can order the OEM sensor from the US MB dealership and install it, maybe it can work. But this is only a guess....I must be said TPMS display is an important safety function. And GLS is mention the SUV's S-class....The liar Mercedes. If S-class have the feature why GLS does not have.
BTW, they also check others GLS 450 and 580 in lot, all of them don't display the digital number.
#57
2020 GLE 450; 2023 BMW M2 Coupe
TPMS
#58
This is really cheap on MB's part - what, to save $100 per car? I believe it's more than sensors; the system in Canada is based on wheel rotation differences so is an entirely different one. I don't think retrofit is feasible. Canadians can comfort themselves in the fact they get better intelligent headlight function.
#59
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
Sorry I don't have my car and I can't go out and check, so I'm working from memory.
#60
yep, you're right. it's on the service -> tire pressure. And I can not got the digital number for tire pressure and temperature here.
#61
Today, I used the TPMS reader to try to read the tire pressure and temperature. The TPMS machine I purchased from China 5 years ago and I upgraded the software today.
An amazing thing is that the TPMS reader can read all of the information from the wheel sensor.
BTW, the wheels are aftermarket I purchased from MB dealership for winter. And the valve's cap is plastic not metal. My OEM 22'' high-preformation wheel have the metal valve cap.
So, I guess in Canada the AMG and MAYBASH, the MBUX system is different others class, such as my GLS580 2021 model. The sensors are here, and the sensors get all of the information about the tire pressure and temperature, but it can not send the information to MBUX to display on the multifunction's screen.
I also think the dealer can not activate the TPMS digital number display because the software block it! If someone can download or get the US version MBUX and replace the Canada version, it should be work.
marchgroupinc (02-15-2021)
#62
#63
TPMS Sensors, module and programming required
Here is an update of how it is possible to add TPMS with actual pressure readings for those GLS/GLE models in countries that do not have it like us here in Canada. It was a lot of work but this is important to me so I can monitor my tire pressure changes while constantly changing loads and extreme temperature changes. All my vehicles (made in USA to Canadian spec.), have this even my travel trailer so I do not understand why it is not standard equipment in Canada. I hope this helps some others.
I now have the tire pressure reading on my Canadian spec. GLS 580. I added the TPMS sensors, TPMS module and a programming coding change to get it to work. The sensors are the valve stem type so tire removal is required. The TPMS Module gets mounted on the underside of the vehicle under the front right footwell, there is a mounting stud there for the device. I found a rubber plug in the floor pan to the rear of the module to run the wires through. The front carpet and RHS front seat must be removed to wire the module into the CANBUS and power and ground. You may get away with not completely removing the seat but I found it easier to get it out of the way especially to run the wires through the rubber plug. I did not disconnect the power to the seats because I did not want to have an issue with airbag lights and I am not familiar with the correct way to disconnect the 48 volt power. I used the ground point that was there under the seat. The power wire runs all the way back to the right rear fuse box location 467. The fuse box was loosened to get the connection in the correct location from the rear. Added a fuse. The CANBUS wire was run to one of the available spots on the connection point in the diagram. Coding was required to activate it once it is installed. The Mercedes ME app does not show the actual tire pressure (with the updated Canadian version) it still shows "Tire Pressure is Within Normal...". If you have the older version like some other countries maybe it will show. Next time I travel to the US I plan to download the Mercedes Me app there to see if that will give me tire pressure readings again. I contacted Mercedes Canada CS and asked about getting the old app to read the tire pressure but got a runaround stating it is not available on the GLS.
TPMS module location under floor
TPMS Module
Black wire runs to rear fusebox
Canbus connection violet wires
TPMS Module
The following 4 users liked this post by marchgroupinc:
