GLE 53 noisy suspension
#76
Received 1,483 Likes
No more MB:(
Originally Posted by tstexpert
Not sure if this is temporary.... <ore power? GLE 63S?
#77
Received 1,030 Likes
2024 GMC Canyon Denali..... 2018 Audi SQ5
A tune will help either model.
Ron.s (06-12-2020)
#79
Received 1,182 Likes
2020 GLE 450; 2023 BMW M2 Coupe
53 vs. 580
GLE 53 - 0-60 5.2s; 18/22 City/Hwy
GLE 580 - 0-60 4.9s; 17/21 City/Hwy
#81
My dealer lent me a 2019 GLC. This will be the 4th week 53 in the shop. I just got update this afternoon, MB Canada escalated this issue and they been in contact with Germany for the passed two weeks. There might be a design problem, and looking for a fix. Maybe they will send out service bulletin for 53 soon. Either a bad batch of Active ride control or some ride control module is faulty.
#82
They ask me to take the car back Thursday since the 53 is just sitting there awaiting for tech support from Germany. Right now the car makes slight noise going over bumps with new active ride sway bar. They did admit from Germany they really don’t know what’s wrong need sometime to figure it out, might end up changing air suspension. I have a feeling they already order new air suspension but parts shortage. Because the advisor already telling me he will book me in soon as the part arrive.
#83
‘I have the same noisy suspension problems with my amg gle 53 suv.
could you please give the exact parts name and number# you have replaced to get rid of the noise?
my dealer is struggling to find the parts that needs to be replace.
thanks
B.Onayemi (05-20-2022)
#84
Hello,
thanks
thanks
#85
This is the front active sway bar system. They went through 3 updates make sure you get the latest one which is the one I post new part.
Old part number 167-323-83-00
New part 167-323-98-00
mikapen (02-05-2021)
#86
I have a 2019 CPO AMG CLS 53 and I have a squealing noise at a low rate of speed and very loud when turning the wheel to left...sounds like brakes but i'm actually not braking when it occurs....It takes about 30 minutes for it to happen...does not do it at first....took to dealership 3 times and they said they cannot replicate ..seems like suspension or something in wheels....so frustrating...owned the car just a month
#87
I experienced the same issues, the noise was driving me crazy but every time I took to dealer they said nothing is wrong. Took me finally about 4 months I finally able to replicate the sound and drive in it. I drove it really hard for a good hour before the appointment and took the tech on a test drive with me.
#88
#89
Performance wise they are pretty close, but I suspect the 580 will feel a little punchier. The fact that the 53 gets slightly better mileage and is an AMG model would shift it to that for me if I was in that market.
Youtube video
Acceleration 0-100 km/h:
- 4.3 s (stock 4.5 s)
- 590 Nm (stock 520 Nm)
- 368 kW/500 hp (stock 320 kW/435 hp)
- Vmax: 250 km/h / 155 mph (stock 250 km/h / 155 mph)
#90
Received 1,606 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
Do you also have a CLS 53? I tried to ''warm'' it up as well and it never did it for the tech. Did they ever figure out what it was? From research I've heard that its a manufacturer defect that the tires rub the fender once the car heats up and parts expand. Please let me know what the solution was! I am in talks right now with MBUSA corporate for a sales incentive since I have negative equity after a month of ownership. I am ready to trade the CLS 53 in for a CLS 450....
Even if the tolerances are mm perfect, tire flex should induce clearance issues. Standing still, you wouldn't be able to slide a piece of paper between the tire and fender, which we know isn't the case.
Where did you hear that (strange) theory? Have you hit a curb?
#91
Vibration at low speed
Hey Tery, glad to see you got your 53!!
I notice a slight vibration with my winter wheels. I feel like the air suspension should be soaking it up. The wheels got re-balanced and they're good, so it's not likely the wheels.
If my OEM wheels go back on and I still have this issue, I'm going to bring it to the dealer.
They checked wheels, tires, swap them, checked engine, replaced drive shafts, checked injectors, changed engine oil, spark plugs, roadforced tires and wheels.
The vibration is still there and its speed dependent, it doesn't change if you manual downshift...
Did you fix your vibration at low speed?
Has anyone noticed a vibration with their AMG GLE 53 at low speed?
Thank you
#92
ISG problem will not register any fault on engine management system. I used to get low speed vibration accelerating out of 30km from school zone. Dealer update the system that was back in 2020 June. Your car is a later production date might already had the update.
if the dealer can check the vibration alway happen when the ISG is engaged in a test mode or some sort. That might guide them in the right direction.
#93
So just got the car back from replacing MBUX control module and did the service A and place front windshield. With in a day now suspension multinational light came on again.
mikapen (02-17-2021)
#96
My recall is booked for this coming Thursday! When I got the letter, I thought of Tery's post.
#97
At this point full year of ownership I been in the dealer in total of 5 times. The longest time the car was in the dealer 1month the other 4 times avg about 2 weeks.
drove loaner range from GLC/GLA/C/Cwagon.
best is the C wagon but I lived with it for the month. Looking forward to see what loner I will get and free coffee from the dealer.
#98
Just got the car back, anyone got this recall highly recommend to do it ASAP.
MB replaced front and rear active sway Bar system to the latest part number
front : 167-323-98-00
rear : 167-326-17-01
on my work order they also replaced the cable and the bolts.
#99
However, new squealing noise started to happen, I'm getting crazy about this car...
#100
Its the brakes....I went to three shops and three shop foreman rode....I traded mine in and got a CLS 450 4MATIC.....this car does it slightly for the first 4 seconds of driving but not as bad as the cls 53. The braking systems are different. My suggestion is to trade it in for the 450! Also, if you look online, you will see a **** load of cls 53's in the 2019 range...all low miles as people are dumping them.
