My first and only was that you could set the lift gate to open to whatever height you’d like.
Quote:
how can you do that. I can’t open the truck in my garage as I am always scared it will hit the opened doorOriginally Posted by JustBlessed
Ron.s
close
- Join DateMay 2018
- LocationBoise
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2024 GMC Canyon Denali..... 2018 Audi SQ5
Liked:1,040 Times in 704 Posts
Stop it at the height you want and then hold down the button until you hear beeps.
bigpern23
close
- Join DateMay 2019
- LocationNew England
- Vehicle(s) I drive2020 GLE 450 AMG exterior
Liked:125 Times in 72 Posts
This is a request, not an actual tip, but I'm curious if there's a way that I can move the information available in the right side of the central display to the left (or vice versa)? Specifically, I'd love to be able to customize my display to show the tachometer on one side and the fuel consumption on the other. Both are natively on the right side of the display.
Quote:
In the handbookOriginally Posted by JustBlessed
When it’s hot, hold down unlock on key fob when near vehicle to roll down all windows. If you have ventilated seats, it also activates seat ventilation!
Ron.s
close
- Join DateMay 2018
- LocationBoise
After you have had your GLE for a month or two browse the manual and you will find a lot of helpful info. There is a lot to this vehicle depending on Accessory options. For new owners.....
First tip-Quick Access button(center button with car symbol left of trackpad)-go through the settings for Assistance; Vehicle; Light & System. There are a number of user selections for your customization.
Second tip-Do the same with the left steering wheel control. Home button upper left & scroll through the options using the mini trackpad.
One tip for those with Air Suspension that makes me scratch my head....
You can configure one driving mode to suit your preferences to Individual or “I” mode. When done save it with your individual settings on the door panel. Then if you are in that mode when you turn off the car a banner will appear when you start off letting you return to I mode with one touch. Someone went to a lot of trouble to overthink this since as a practical matter it’s useless. It would be easier to just leave the car in the last mode rather than switching back to Comfort. Also it’s just 2 clicks up on the mode toggle switch to I mode, one click to Sport. Switch is left of the trackpad label Dynamic.
A lot of thought went into the MBUX system but the results aren’t always perfect. Since it’s a cross platform system look for more refinement in the future.
Quote:
wow I didn’t know it activates the ventilated seats too. Originally Posted by MercOne1
ExploreQuote:
I don’t think you can. I wanted to do this same exact thing.Originally Posted by bigpern23
what do you mean save it on the door panel? Your individual mode you set up gets saved through the memory seating controls? Originally Posted by Ron.s
After you have had your GLE for a month or two browse the manual and you will find a lot of helpful info. There is a lot to this vehicle depending on Accessory options. For new owners.....First tip-Quick Access button(center button with car symbol left of trackpad)-go through the settings for Assistance; Vehicle; Light & System. There are a number of user selections for your customization.
Ron.s
close
- Join DateMay 2018
- LocationBoise
Quote:
You can check in the owners manual, that’s the way I recall doing it but it’s been almost a year. The save function covers more than just the seats....steering column, mirror, etc.Originally Posted by JustBlessed
Quote:
I think there’s an option to bring up that banner every time you start the car to select the last set suspension level.Originally Posted by Ron.s
Quote:
Individual mode nothing to do with seat controls. as far as I am aware.Originally Posted by Ron.s
Quote:
I wish there was a way the car could lower or at least the seat lower all the way down for easier entry. I don’t have that option that does that and I have no idea why a $67,000 truck didn’t come with running boards. ( maybe because AMG appearance pack) but I’m only 5’4 and it’s just a bit high for me to step right up into seat. Originally Posted by tinman831
Ron.s
close
- Join DateMay 2018
- LocationBoise
OK, I looked back & here’s what the manual says....page 174. I might have been doing it wrong going from memory.
Configuring DYNAMIC SELECT (multimedia system)
Multimedia system:Settings/Vehicle/DYNAMIC SELECT
Setting drive program I
# Select Individual Config..
# Select and set a category.
Switching the reset display on/off
- Switch Request at Start on or off.
- The prompt appears only if the previously active settings deviate from the standard settings.
Quote:
In UK AMG appearance pack and running boards standard. Originally Posted by JustBlessed
Quote:
I wonder how they would look being put on after the fact Originally Posted by Philamg
thanks for this. A little confusing but I’m gonna go in my car and try it out. Originally Posted by Ron.s
OK, I looked back & here’s what the manual says....page 174. I might have been doing it wrong going from memory.Configuring DYNAMIC SELECT (multimedia system)
Ron.s
close
- Join DateMay 2018
- LocationBoise
Quote:
The A drive program would be better described as “Comfort Mode”. IMO, it’s an effort gone wrong. It’s no real shortcut and the banner doesn’t always appear. If you back out of a parking spot soon after starting the car it my not ever appear or at times it appears after you are driving and you only have a second or two to select it.Originally Posted by JustBlessed
bad habit
close
- Join DateApr 2019
- Vehicle(s) I driveA
Liked:141 Times in 101 Posts
Yep the banner doesn't always appear and even if it does, it is at times buggy because it doesn't remember the full setup (e.g. it frequently "forgets" that I had Auto-off turned off).
Quote:
yup I noticed that. Originally Posted by Ron.s
Favorite feature is “AUTO HOLD”; pushing down hard on the brake once coming to a stop allows you to take your foot off the brake and puts the car in Park. Putting your foot back on the accelerator automatically disables Park and the car starts to move. Great when in traffic or at a long light. Audi eliminated this feature and glad to be back in an MB for this feature alone.
Quote:
Nice. I didn’t know about this feature. Will give it a try soon. Love this thread. Already solved one problem related to the trunk opening height. Originally Posted by monwen
Quote:
Pressing the brake pedal again also releases the Hold. Originally Posted by monwen
On this feature - this is actually "Brake Hold" where all four brakes are locked against the rotors - the transmission is still in gear - the MB is held in place with the brakes.
"Park" is different ..
