Rear seat belt recall
Old Jan 17, 2021 | 11:32 AM
JustBlessed's Avatar
2025 e450
I can not believe what I just saw and read in that picture and instructions. Did they really assign a part number to a friggen zip-tie?
Old Jan 17, 2021 | 11:44 AM
BACnMercedes's Avatar
19 E63s, ‘24SQ8, wanting another gas guzzling V8
Yeap! I pointed that out to wifey this morning when we were looking at stuff in the forums. Hilarious isn’t it!
Am I correct to assume now, though with so many asking about how to get the seat out to fish the seatbelt out, that when my kid drops something in the seats now it’s gone forever?
Old Jan 17, 2021 | 11:46 AM
2025 e450
I would have to say that’s a pretty
Good assumption. Lmaooo
Old Jan 17, 2021 | 12:10 PM
mikapen's Avatar
That's the Feds for you. "If it only saves one life...."
Old Jan 17, 2021 | 12:37 PM
jtjbt20x's Avatar
2021 GLE450W4 SUV
Originally Posted by WA3CUJ
I will have to search those screens again. I could not find one that showed battery voltage. I can drive 30 minutes to a destination and then 30 minutes back home and still no change. I can bring up the app while the engine is running and it still shows partially charged. This started about a month ago. I've put it on a trickle charger for 48 hours and the charger never indicates that the battery is charged. Time to get it checked before it leaves me stranded.
Click Home on the touchpad, scroll to the right and click on Info then select Engine. The voltage is on the bottom left of the quad display.
Old Jan 17, 2021 | 12:46 PM
jtjbt20x's Avatar
2021 GLE450W4 SUV
There's another document on the that website that says the affected vehicles were built from MAY 30, 2017 - JUL 24, 2020. I guess that must be a mistake.
Old Jan 17, 2021 | 09:22 PM
  #32
user 7208224's Avatar
2020 GLE 350
I finally took the time to take a close look at the completed work on mine. It doesn't look like the picture in the service bulletin in a previous post. There is nothing visible from above. Sticking my finger down around the belts I was able to feel the "zip-tie". What I felt was nothing like any zip tie I have ever used in wiring. What I felt was round rather than flat. Not that that should matter. Also the center belt still had enough free slack to lay over in the indentation in the seat as designed.
Old Jan 19, 2021 | 08:23 PM
  #33
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
On the flip side, this issue doesn't impact GLE's with a 3rd row. The second row seat-belt buckles are secured differently to account for the power second row seats tilt forward feature to allow access to the third row...so yay.
Old Jan 20, 2021 | 08:57 AM
  #34
TNS550's Avatar
2015 MB S550 & 2020 MB GLS 450
Originally Posted by jtjbt20x
I was shocked too for a zip tie fix to an $88k vehicle.
You have to understand this is an upscale vehicle, so only the best equipment used. Had it been a $50,000 vehicle, you just wrap duct tape around the two buckles.
Old Jan 20, 2021 | 12:31 PM
  #35
jtjbt20x's Avatar
2021 GLE450W4 SUV
Too funny!
Old Jan 20, 2021 | 01:58 PM
  #36
zengshengliu's Avatar
2020 Mercedes GLE 450
To be fair, zip tie is a valid form of securing items in car. It is especially useful when securing wire harness to certain location which is sustainable to vibration. There are different forms of zip ties that is used in different location for different purpose.
But, in my case, the zip tie (that looks different than normal zip tie) that is used to secure the seatbelt buckle is located below the seat cushion, which means the buckle itself can still be pushed below the cushion.
Its hard to tell from the diagram from the recall notice where cable tie should be, but I would think it should be right below the right buckle (at cushion level) which will prevent the center buckle from being push down.
By the way, I was able to fish out the center bucket with just the front portion of the seat cushion lifted. The reason I asked if anyone know how to remove the entire cushion is so that I can check to see if I can "relocate" the cable tie to a higher position.
Old Jan 25, 2021 | 12:31 PM
  #37
Just want to update on my situation.
I visited the service department this morning, and they determine that the first cable tie wasn't install in the correct position so it wasn't effective on holding the middle seatbelt buckle in place.
They installed a second cable tie on a much higher position (cushion level) and this does prevent the middle buckle from being push down under the cushion.
Old Jan 25, 2021 | 02:53 PM
  #38
2025 e450
I just fastened the buckle to prevent it from falling down. Rarely do I have someone in that seat anyway.
