Installing the MB dash-cam
So I have purchased the MB front and rear dash-cam, along with the harness, memory card etc.
However, there are no instructions on how to install the harness. I am an electronics engineer so I could cut-off the connectors and find suitable sources for the wiring (eventually) but I would much rather install this as it is supposed to be.
I have been advised by the supplier that the details are in the Mercedes WIS database, but obviously don’t have access to it. Has anyone on the forum installed this harness before? Or know how and where it’s connected. The harness setup part number is A213 820 93 03.
I have a new GLE late 2019 (167).. I know that they are now releasing them with the dash-cam app via MBUX if you have the org reality in the car (which mine does), but mine only has a grey’d out option in the mbux when entering in engineering mode. Maybe in the future they may integrate into a software release? However, I need the setup in the car for some long journeys I have planned... COVID allowing!
So any advice on the harness installation from anyone would be grateful.
For my use, as I travel frequently across Europe .. hence I would like to install them
It includes:
1) The front and rear camera units
2) 2x window sticky pads for camera mount units
3) Wiring harness
4) Memory card (installed on the front camera unit
The connections on the harness are what I would like to identify, they are:
a) Red wire - must be +Ve supply, (unknown if it should be switched or not)
b) Black - Earth
c) Thin wire with blue connector - unknown.
d) Also supplied with a separate blue connector and a separate 25 fuse
hope someone can help...
Hence I have purchased the MB front and back camera’s setup which is still recommended by MB for the Europe cars. This product DOES have the option to switch on if the car experiences a bump or night parking etc.. I recall reading that in the manual.
My car was bought in the UK and was one of the first there... being registered in April 2019 by MB, used as a demo car... it have every conceivable gadget but hence no dash cam option!
Did you solved the problem ?
