Gle 350 2020 battery
Old Apr 22, 2021 | 03:09 PM
Steve Vi's Avatar
Glee 350
I can't find my battery? And is Anybody had a battery drainning?
Old Apr 22, 2021 | 03:24 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Battery location
Under the driver's seat. Lift seat all the way up and forward and look under the plastic panel.
Old Apr 22, 2021 | 03:59 PM
Steve Vi's Avatar
Glee 350
No plastic panel!
Old Apr 22, 2021 | 04:01 PM
maalox's Avatar
You need to look from behind the driver's seat, from the 2nd row area. Remove the carpet mat and you'll see a little plastic panel near the foot air vent.
Moving the driver's seat all the way forward and up just makes it easier to access.
Old Apr 22, 2021 | 07:01 PM
My explanation was not very complete!
Old Apr 23, 2021 | 06:23 AM
Steve Vi's Avatar
Glee 350
Do you have a picture?
Old Apr 23, 2021 | 09:29 AM
marchgroupinc's Avatar
2020 GLS580, 2023 Corvette Z06
Could the 350 have the 12V battery in another place because it is likely larger than the 12V batteries in the other models that also have 48V? If not under the driver seat I would check under the passenger seat on this model. To answer your question about battery draining - it is common for the battery to drain if not driven very much. Use a battery maintainer to reduce the risk of the battery dying if not going to be driven any distance for a week or so. You can also connect to the battery by using the jump start connections under the hood.
Old Apr 23, 2021 | 09:32 AM
Try this thread for pics
https://mbworld.org/forums/gle-class...v167-400d.html
Old Apr 23, 2021 | 09:53 AM
Old Apr 23, 2021 | 11:07 AM
Steve Vi's Avatar
Glee 350
Thanks I found it
Old Apr 23, 2021 | 11:40 AM
mikapen's Avatar
@GregW / Oregon , is the terminal you have often described as the negative one to disconnect to reset the car, the one closest to the bottom of the pic, or the one that attaches to the battery post?
Old Apr 23, 2021 | 11:43 AM
Terminals
The battery post. The white paint on the other terminal tells you that's not to be messed with.
Old Apr 23, 2021 | 11:48 AM
Steve Vi's Avatar
Glee 350
that's what I did to reset ! Thank you all
