No Oil Extractor? 2021 GLE 350
Old May 4, 2021 | 01:41 PM
cpark02's Avatar
2021 GLE 350
Hello,
I've done some research and couldn't get a clear answer.
Since this car has no dipstick, it's absolutely impossible to do any oil extraction from the top side correct?
So even when we take it into the dealership for an oil change, they will also just drain from the drain plug underneath?
I'm not sure why they would make it harder for themselves like that as well.
Unless there's another tubing on top side that you can use to extract the oil...
Thank you!
Old May 4, 2021 | 05:08 PM
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
Correct, engine oil is drained via the oil drainage plug on the bottom of the oil pan.
Old May 4, 2021 | 05:11 PM
cpark02's Avatar
2021 GLE 350
Oh man okay. Thank you very much for the reply!
Old May 5, 2021 | 08:28 AM
chassis's Avatar
2017 GLE350 4MATIC
Dealers use bottom drain on vehicles with a dipstick and where WIS says to use top extraction. My dealer uses bottom drain on my W166 with dipstick and WIS says to top extract. Dealers do whatever they see to be in their own best interest.
Old May 5, 2021 | 10:48 AM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Oil change
Originally Posted by cpark02
Hello,
Cars are almost always on a lift when serviced at the dealer, so bottom draining is not more difficult, and is more reliable.
Old May 5, 2021 | 11:27 AM
cpark02's Avatar
2021 GLE 350
Okay that makes sense then. Just also for curiosity sake, are there advantages to having the filter on the topside than on the bottom? I assumed they put it topside in the past because they just used extractor method and changed filter from the top. So its quick and they don't need to go underneath.
Old May 5, 2021 | 12:43 PM
mikapen's Avatar
I can think of a few reasons.
The filter drains when the oil drains. More complete draining, less mess - therefor easier to check for leaks. Easier to access than when on the side of the block. Fun to look at.
Old May 5, 2021 | 12:47 PM
cpark02's Avatar
2021 GLE 350
All valid points.
Thank you!
Old Jul 1, 2022 | 06:24 PM
FireRx Captain's Avatar
2020 GLE 350 4Matic, 2016 E350
I'd like to know the answer to this question too since I service my own mercedes. I'm in the market for one of the new ones nd it will be my fifth Benz.
Old Jul 1, 2022 | 07:37 PM
No topside oil change
There is no way to extract from the top. Even my 8 year old M4 did away with the dipstick. If you have a floor jack, ramps and jackstands it makes the job more difficult, but also more reliable. Other than eliminating one more accessory on the engine, I would guess the fact that it encourages owners to go to a dealer is a reason.
Old Sep 25, 2023 | 02:59 PM
Quick Silver's Avatar
2019 CLS450 4matic, 2013 CLS550 4matic (totaled), 2005 C55 (traded), & a Ford F150
Stupid Question
Can you extract/siphon oil from the same hole that you add oil? I just bought a CLS450 from out of state and recently got the "Reduce Oil Level" warning and according to the cockpit display, it's just barely above Max and there's no dipstick. Standing by to get trashed for asking.
Old Sep 25, 2023 | 04:08 PM
chassis's Avatar
2017 GLE350 4MATIC
No. But you can add oil by removing the black plastic cap with the yellow oil can icon.
Old Sep 26, 2023 | 01:50 PM
Thanks for the pithy answer but can you elaborate? If you can add oil by removing the plastic cap with oil can icon, why can't you suck oil out? Is there a screen or some other obstruction that would prevent a plastic hose from reaching the oil pan? Isn't it just a fill tube? Additional sarcasm welcomed.
Old Sep 26, 2023 | 07:12 PM
chassis's Avatar
2017 GLE350 4MATIC
Thanks!
You mean snaking a Mityvac suction tube into the engine via the oil fill cap? While I can't say with 100% certainty a tube can't be inserted all the way to the bottom of the sump, by way of the oil fill cap, it's a folly imo.
If you can get past the cams, you need to find an oil return path through the cylinder head casting, into the engine block and hope that it has clear line of sight to the bottom of the sump. It's a low percentage shot. A waste of time.
Change the oil the way Gottlieb intended, via bottom drain. It's so easy.
The most time consuming part of the job is removing the belly pan. Invest in a cordless ratchet and the time for this step is cut in half. If you have air suspension, raise the chassis to "Car wash" height and you gain 3.5 inches under the car which makes all the difference.
Old Sep 26, 2023 | 07:43 PM
mikapen's Avatar
Good idea. I hadn't thought of that.
Do you have to leave the door open, in order to keep the car from changing height with the ignition off?
Old Sep 26, 2023 | 08:27 PM
howardx's Avatar
2022 GLE 350
I just drive up on Rhino ramps and put jack stands under the suspension for redundant safety. 8x 8mm screws under the belly pan is quick work with my Milwaukee stubby. Then 14mm drain bolt. Be careful though, the oil shoots to the driver side.
Old Sep 27, 2023 | 10:59 AM
Thanks!
Chassis, thanks for the detailed answer, it was very helpful and saved me from doing something stupid. I was just trying to find an easy way to drain about half a quart as it was overfilled at last oil change, which was performed out of state.
