Map Update Available (US Market)
#51
Thanks, guys, am on a mac. did this once, so managed before, but now am feeling dumb. it did see my usb drive and start the download process once you told me the cache directory is NOT the USB drive, and I pointed at a directory it could use (duh). Hey, only have to do this every 6 months or so... :-)
Appreciate all the help.
#52
On my Mac, I used the Disk Utility to erase and reformat the USB flash drive into the Exfat format. The Mac and the MB Download Manager program were both able to see the drive. Once I connected to the MB using the USB-C to USB-A adapter in the non-carplay port near the cupholder, it only took a few minutes for the dialog box to appear. I went to software update under System on the main screen, but I don't think it was necessary. After each update, I used Disk Utility to erase and reformat because the Mac OS Finder could not read the files. It really is easier than it sounds.
jaxslk (06-04-2022)
#53
I was looking at the app and see that the OTA update is available for my car related to the map (I haven't update mine yet as it is in the shop). Either I am very lucky to see it that early, or Mercedes is starting to push out map OTA update faster.
#55
Received 3,834 Likes
2019 C63CS
Are these the correct steps?
Ignition on or off?
1. Format USB with exFAT
2. Use In private browsing to go to https://www.me.mercedes-benz.com/pas...y-vehicle.html
3. Download stuff onto USB
4. Plug USB underneath armrest
5. Don't remove drive after rebooting
Ignition on or off?
1. NTFS works, too
2. In private browsing not needed
5. Yes, remove drive while rebooting, otherwise it may detect the update again, but it will recognize that it's no longer applicable, so doesn't' really matter when you remove it.
#57
Received 2,501 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
#58
2019 C63CS
Imanone (02-01-2022)
#59
Yup, that is the preferred method but for some reason the newer cars don't have the sd card slot anymore.
#60
I got the same update last night except mine says Canada and Alaska.
#61
decided to download the entire country for my GLE 450. which of the usb ports do I put the drive into? its very confusing since the one on the right in the front cupholder section is the ONLY one that the dash cam sees and uses and for some reason the one in the armrest cannot play media when the one in the front is in use. its very frustrating to not be able to use the dash cam AND play media at the same time. regardless the primary concern for me is which port do I put the stick into in order for the system to update the navigation. thank in advance
#63
#68
marchgroupinc (02-02-2022)
#71
2023 GLE 450 4matic
I normally update with a USB but let it do its thing over the air this time. After it was done, I was prompted to restart the system for the update to take effect. I thought it would restart the GPS but it rebooted the entire system.
jaxslk (06-04-2022)
#74
2019 C300 Cabriolet, 2022 AMG GLE 53
Thanks ! Just did my maps (all of N.A.) manually. Took about 20 minutes to load them all into the car. Formatting the USB as ex-FAT was the key. Until I read about that, I kept getting the error from the download manager that it could not find my device to write to. Should have slowed down and read the forum all the way first ! LOL
jcapotos (06-07-2022)
#75
