Lithium replacement for 12V Battery
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hi,
Has anyone replaced the 12V lead acid battery with a lithium? I have a 2019/2020 GLE300d, and with the car not being driven much the lead acid battery is giving me some alerts in the car and Mercedes Me app.
If I have to replace the battery, I'd rather replace it with something with a longer lifespan. I'm in Australia.
Thanks,
Shane.
Thanks,
Shane.
Hi,
Thanks,
Shane.
Thanks,
Shane.
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
I am not aware of any vehicle that uses a lithium battery as the primary 12 volt battery. If you find something that will work, you should consider the charging process. Having said that, I started getting "Starting Battery Partially Charged" warnings in the Me app. My dealer ran a load test and found it was a bad battery. They replaced it under warranty.
Received 1,032 Likes
2024 GMC Canyon Denali..... 2018 Audi SQ5
My 2020 GLE 450 did the same thing at the perfect time. I had just dropped it off at the Dealer for warranty work and mid day I got the notice of starter battery critical. I assumed that they had disconnected the ground for some reason but sent an email to the Shop Foreman. They put it on a charger overnight (per MB) and tested in the AM. They replaced the 12 volt AGM since it failed the test after charging. That was two years ago so the procedure may be different now.
With COVID it could sit for several weeks without being used. On one trip to the dealer, they just charged it overnight and said it was from lack of use. It started again about two weeks later. Remote start would not work in that state. I was in for a recall and brought it up again. That is when they did the load test. Has been fine ever since.
pierrejoliat (02-06-2022)
2010 E-350 4-Matic
I found these as viable replacements. battery A0055411001 or Interstate costco item 1355853
I ended up getting a Duracell SLI49H8M - It was slightly bigger than the battery that I replaced, but it fit the battery tray fine. I had a vent hole, and replacement was fairly simple. I never had to resync anything afterwards.
Received 1,186 Likes
2020 GLE 450; 2023 BMW M2 Coupe
12V Battery
2023 GLE 450 4matic
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/320x300/chins_0bafd59d0186b070fc2ca53f3784a6e4488aa789.jpg)
LifeP04 batteries
And Li-ion is suited for that application. What I was referring to is the 12 volt batteries widely available that look just like a conventional AGM but internally use 4 Lithium Iron Phosphate cells and a battery management system. The BMS can't handle the current of a car starter and they can not be charged below freezing.
2023 GLE 450 4matic
Not questioning that this is usually the case, but this one claims to work for both starting and deep cycle. https://dakotalithium.com/product/da...ttery-1000cca/
CHARGE VIA ALTERNATOR Drop in replacement for lead acid and AGM starter batteries for vehicles and outboard motors. NOTE: THE DL+ 60Ah IS LIMITED TO AN ALTERNATOR CHARGING PROFILE OF 80 AMPS OR LESS.
I'm not certain of the alternators in other GLE's but my 2020 GLE350 has a 200 amp alternator.
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/960x727/gle_alternator_46d432c279eadf896c49f7000f2e29dffd27eecc.jpg)
Why stay with Li-Ion battery?
Yeah, a little ****. The battery lives at the back of the trunk. The Li-Ion one is ~50% the weight of a standard one. When you’ve got a ton of weight saving measures like a carbon fiber roof, trunk & driveshaft and aluminum doors & hood, I like to preserve the design intent. And it’s durability speaks for itself - 7.6 years and still strong.
Lithium still too scary for old-schoolers
GregW / Oregon (02-09-2022)
Received 1,637 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
2023 GLE 450 4matic
This old-schooler has built and commissioned several hundred thousand watts of LiFePo4 batteries for solar storage using prismatic cells and JBD BMS. It's a battery technology that must be respected or it will bite you. I can supply pictures of burned RV's and boats belonging to people that took a casual attitude and dropped them in where they didn't belong. In most cases the BMS will save the common idiot from disaster but not always. To each their own...
Senecat (02-10-2022)
But since you want a lambast "old schoolers," show us your post in this thread about your lithium conversion, so we can play along.
Maybe the new schooler in you has Special Powers!
Lucky 777 (02-10-2022)
https://mbworld.org/forums/e-class-w...r-install.html
Sheesh, another tough crowd! I though "old schoolers" had thicker skin! Just a joke man! Like I said, no one cared, so the thread just died on the vine. I have lots of updates and conclusion I could add to it if interested. Here ya go:
The crowd was depraved, on account'a they were deprived.
We won't be fooled again!
I think apologies are in order. Unjustified attack. (We also haven't seen your other posts, so if they died, it's not the V167 folks. It's you!)
