GLE450 Spare Wheel
Old Aug 10, 2021 | 03:28 AM
Stuart Morley's Avatar
W167
GLE450 Spare Wheel
As there is no spare wheel in the car I was looking to buy one for when I travel to remote places or abroad.
I know there's nowhere to put it other than in the boot but that's fine.
It seems the space saver spare wheel is out of stock at MB at the moment and the bolt are £15 each !
Does any one know:
1) If the W166 space savers spare would be ok?
2) If I took a spare full size wheel and tyre would a W166 one be ok. I read somewhere about the bolt size changing?
Any other help or ideas would be great.
Old Aug 10, 2021 | 09:14 AM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
The bolt changed from 14mm to 15mm so you might have to drill your holes larger. Why not just get a normal size tire and wheel for a spare? The slightly larger size vs the practicality of one that would work normally might be worth losing a little more space. Then there are rooftop carriers that you might tweak for the spare.
Old Aug 10, 2021 | 09:25 AM
W167
Yes thats a good idea. Are you saying the alloys for the W166 and W167 have different sizes holes? A full size wheel is a great idea.
Old Aug 10, 2021 | 09:41 AM
Ron.s's Avatar
The factory wheels would normally have a 1mm smaller hole W166 vs V167. My aftermarket wheels did not need drilled…probably a case by case evaluation.
Old Aug 12, 2021 | 02:12 PM
raleighnick's Avatar
2020 GLS580
Try eBay. The part number is A1674000300 for the 19 inch spare that works on both the GLE and GLS. I was able to find one for 280$ when the dealer wanted $480. The spare M15 lugs are also available for about $38 for the set of 5.
Old Aug 12, 2021 | 09:30 PM
mikapen's Avatar
You might give the folks at Modern Spare .com a call. The GLC forum has purchased lots of spares, jacks etc from them.
They seem to produce a quality product. From Colorado.
They don't have a spare listed for the 167 cars, but they might be able to source a kit.
I called about our GLC, and the person I spoke with was quite knowledgeable, no BS.
Listing for E-Class- https://modernspare.com/product/2017...e-kit-options/
Old Aug 13, 2021 | 05:30 PM
W167
Nothing for the GLE
Old Aug 14, 2021 | 04:47 PM
mikapen's Avatar
Nothing for the GLE
Did you call? They have more offerings than they list online.
Old Aug 15, 2021 | 08:46 AM
W167
No I didn't call. The other issue is I am not in the USA so shipping to the UK would be expensive.
In the end I bought a second hand wheel for the 167 and a pre-owned tyre for £200 all in. Has the benefit that if I need it it just pops on like a normal tyre. It does take up a lot of boot space which isn't really an issue as I will only use it on long journeys.
