Just ordered the RJ Automotive Coding package
Old Apr 23, 2024 | 01:57 PM
  #176
TonyF61's Avatar
2022 GLE 450
Originally Posted by mikapen
I also wonder if I have lost some brightness with the RJ coding.
I'm interested as well, and will be watching for your experience.
I wondered what he meant by "flicker," but I didn't ask at the time.
I was wondering if it had to do with a frequency incompatibility with the cameras.
Not sure either. I figured I would ask when I schedule coding. If it sounds schetchy, then I will just pass on it.
Old Apr 23, 2024 | 09:31 PM
  #177
graffixnyc's Avatar
2024 GLE 450 4MATIC
Originally Posted by mtg-gle
Let us know what you think. I had RJ reprogram mine about 2 years ago. It took about 20 minutes. I no longer get flashes from other drivers - actually have never had a flash afterwards. When you are following another car you will see a black box around the other car and on a curve it is neat to see the black box move with the other car. One thing I would like to know when you try out your reprogrammed lights is, are the brights as bright as you remember? The reason I ask is that I have a 2016 Porsche 911 with the "fancy" headlights but they only do high and low beams - does not seem that anyone does the reprogramming of those to European standards. But the high beams on that car are way brighter than the reprogrammed highs of my 2020 GLE.
So on my way home it worked great. I didn't get a single person flashing me because the high beams were on. I did notice two things though. 1. The animation it used to make from switching from low to high beams doesn't seem to animate anymore. 2. It did seem like the high beams are not as bright as they were before. I honestly don't know if that's the case or reading the posts where people said the high beams aren't as bright just was in my head. I should compare a dash cam video from last night before the mod and tonight with the mod.
Old Apr 25, 2024 | 04:04 PM
  #178
TonyF61's Avatar
2022 GLE 450
I just spoke with RJA. They said that if I enable the brighter lights (like they have in Euro), then I run the risk of flickering. I wanted to do it anyway so that I could report back the results; however, if I am not satisfied with it, then I would have to pay to remove the coding. So based, on that, I will pass on it.
Old Apr 25, 2024 | 05:13 PM
  #179
graffixnyc's Avatar
2024 GLE 450 4MATIC
So I had asked RJ if the coding decreases the brightness of the lights at all and he said:
"Hi it doesn't decrease the brightness, but you have to remember that when its working in matrix mode its shutting off LEDs to dim around traffic so it can appear less bright. But in no traffic its the same brightness"
Old May 6, 2024 | 12:06 PM
  #180
TonyF61's Avatar
2022 GLE 450
Had ILS re-coded last week, sans the brightness. @RJA took less than 5 minutes for coding. They did a great job, as usual.
Old May 6, 2024 | 12:15 PM
  #181
EndenDragon's Avatar
2024 GLE 450​
Recoded because of the update 2.4 that just came out?
Old May 6, 2024 | 12:45 PM
  #182
TonyF61's Avatar
2022 GLE 450
Note sure of version number; I can look tonight. However, It was an "Infotainment system" update that I received on 1/29/24.
Old May 6, 2024 | 12:51 PM
  #183
graffixnyc's Avatar
2024 GLE 450 4MATIC
The 2.4 update didn't revert my coding on my 2024 GLE. The feature still worked after the update for me.
Old May 6, 2024 | 01:54 PM
  #184
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
So you did end up having it re-done for brighter lights? I have my module thing in shipment and then programming later for new 2024 GLE.
Old May 7, 2024 | 06:59 AM
  #185
TonyF61's Avatar
2022 GLE 450
No, I didn't go for the brighter lights as RJA stated that it could cause flickering, and if I wasn't happy with it, then I would have to pay to remove the brighter lights.
Old May 26, 2024 | 07:25 PM
  #186
graffixnyc's Avatar
2024 GLE 450 4MATIC
Did you get the coding code yet? What are your thoughts about the brightness after?
Old Oct 21, 2024 | 03:16 PM
  #187
lexnoir's Avatar
2022 SL 55 AMG, 2020 AMG GT 53, 2015 GL 550
Question
I pulled to trigger on RJ Automotive as well.
I purchased some Chinese plug and play OLEDs which I love. The only issue is my dash reports left and right turn signal are out. But they are not. They work fine. Confirmed with Raj he could code out the errors.
​​I have my appointment tomorrow. My questions is I have a Renntech Stage I tune. Anyone have this if so did you also do the sport+ and what was the impact if any?
Last edited by lexnoir; Oct 21, 2024 at 03:18 PM. Reason: Wrong thread. Needs to be in the S 550 Coupe thread.
