Poor Down Shifting
#76
Wow, that's too bad. Good luck with it. Hope they figure it out soon.
I don't understand how so many customers can have different experiences with similar issues. We both have MY 22 GLE 450. Obviously a different issue than mine; but I often read, on here, about fixes for one customer that doesn't work for others. I find it baffling.
#77
2021 AMG GLE53 | 2013 SLK350 Sport
I don't understand how so many customers can have different experiences with similar issues. We both have MY 22 GLE 450. Obviously a different issue than mine; but I often read about fixes for one customer that don't work for others. I find it baffling.
#78
Received 1,606 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
"They all have it" is a preposterous statement. Not an encouraging statement on their prowess.
However the fact that they're keeping it might mean they've opened a direct line to MB for diagnosis of a different malady. That takes a while, and I think it might be because of the time zone difference.
The Factory requests a specific diagnostic, the next day the US shop reports, the next day the Factory investigates, and so on. But now there's more expertise brought to bear on the problem.
Good luck.
Good luck.
#79
So the dealership contacted MBUSA and opened a case with them Tuesday afternoon.
There was no action Wednesday or Thursday. Today I noticed the car had been taken out multiple times and driven an average of 10 miles. I just tracked it and see that it is in the shop with the ignition on. I suspect MBUSA has agreed to further work though I have not received an update from the service advisor. Stay tuned.
mikapen (04-14-2023)
#80
You have better patience than me. Of course, if the transmission is your only issue, then maybe it’s not a big deal. However, I think our transmissions were very, very similar in their failings. I don’t believe it’s a production problem. That is not to say it can’t be, but most of the major transmission components (I.e., gears, synchros, solenoids, etc.), are machine milled, made or forged and it’s probably hard to mess that up. It’s usually just one giant part that is bolted onto the engine and frame.
Good luck. I wouldn’t accept anything less than a perfectly running transmission. You can drive around a 5-year-old rented Chevrolet that sold for $25k new that shifts better.
chassis (04-14-2023)
#81
Received my car today.
Service advisor called me this morning and said they had been in touch with an assigned MBUSA engineer who directed on steps to take. Among many other things, they replaced the oil in the transfer case and did a valve-body flush along with the obligatory software update (although it had the latest). Did not help. Finally, they removed the FR seat to access CAN connector for the drivetrain and perform an adaptation of the up and down shifts. Did also a transfer case software update. Car is now downshifting smoothly although I'm calling no joy until I put another 100 miles to make sure it is consistent.
They did manage to put in 78 miles on the car in the 10 days they had it for diagnosis and repairs.
The following 7 users liked this post by djgiovanni:
ddeliber (04-18-2023),
HotRodW (04-18-2023),
MBguy013 (04-18-2023),
mikapen (04-18-2023),
nguyensteve (05-04-2023),
and 2 others liked this post.
#82
2021 GLE450
Well I'm happy to hear things are working better for you, @djgiovanni. Unfortunately for me, mine took a dramatic turn for the worse. (That's what I get for celebrating the improvement I reported.) Running several errands in mixed traffic Friday, it reverted to harsh downshifts at every single stop. For the first time it also wasn't up-shifting correctly. Hesitation and lurching were common when moving from a stop or at parking lot speeds. If it doesn't get any worse in the immediate future, I'll have it looked at when I return to have the whistling mirror replaced next month. But I won't deny the frustration is building.
#83
Hi All
I am having the same problem on my 2023 AMG GLE53.
While it downshifts from 3-2 it revs up over 2000 rpm sometimes. When it is “smooth” is goes to around 1,300 to 1,500. Hope the dealership can fix it … I had the car for two month and started noticing it recently. Dealership said it can be due to adaptive transmission.. let see what they find.
I also brought it in to have them check on a whistling sound when I go above 58 mph. I heard from them today and they found the issue. The windshield was too far apart from the roof so they need to remove and reseal to meet the specs. Hope that fixes the issue. My service center is usually pretty good so I hope they can fix both issues.
will fill everyone in if it gets fix
#84
Hi All
#85
First I must say that I admire your determination to resolve this issue with MB. I have a GLE 450 my20 and have the same problem, though probably not as pronounced as yours. I have not pursued this with MB service and don’t plan to. You would think that a 9 speed transmission would shift feather smooth across the spectrum. In my opinion the transmission is trying to rev match as gears down-shift and the software is likely to blame. Lately I’ve been using eco mode and the issue is practically non existent. I’ve noticed I run on full hybrid mode with little or no load on the engine and I’m now getting close to 29 mpg around town. When I apply the brakes the engine re- engages so I’m of the opinion it’s programmed to help bring the vehicle to a stop. The issue we are experiencing is likely the interaction of the mild hybrid system and the in line 6 cylinder engine. Ironically in-line 6 cylinders are well known for their smooth balanced performance, not what many owners are experiencing here.
Sieveboy (05-04-2023)
#86
mm9351 (05-08-2023)
#87
#88
1986 Light Ivory R107 560SL, 2020 Lunar Blue W205 C300 AMG-line
I’d like to chime in as my 9 speed does the same. Sometimes it’s worse than others, and as someone else stated ECO has helped me as well. I also do find that it seems like the car is attempting to rev match on downshift causing it to feel like it’s kicking you in the a$$. I don’t mind the harshness in sport and sport+ but it gets a bit annoying when I’m driving in comfort mode.
A big reason for the behavior of this transmission has to do with its design and construction. The 9 speed multiclutch (MCT) is known to kick in the butt on downshift and that is normal for any multiclutch transmission. However torque converters should be smooth as that is pretty much their claim to fame. What I’m told happened with the 9g Tronic torque converter is that MB took their MCT and adapted it to be a standard torque converter. It is not uncommon for manufacturers to adapt their torque converters into MCTs, it is totally normal, easy to do and saves cash. However it is much much more difficult to go from an MCT to a traditional torque converter and that is the route MB went. In doing so it kept the same harsh shifting found in the MCT because of the transmission’s basic design. At least this is what I’m told and it seems to make sense to me.
#89
2021 GLE450
The following 2 users liked this post by HotRodW:
djgiovanni (05-03-2023),
mm9351 (05-08-2023)
#90
If it were inherent to the design, we would all experience the same behavior. Many forum members here do not have the issue at all, and those of us that do have it don't seem to experience it to the same degree. My GLE has been up and down (mostly down and currently way down), but our GLC's 9-speed has never exhibited the behavior. The difference is so dramatic that I find myself grabbing the GLC keys more and more.
#91
Received 1,182 Likes
2020 GLE 450; 2023 BMW M2 Coupe
Thats true, but then again not all 9 speed MCTs do it either, but they should as it is inherent to their design. I’ve driven some “smooth” 9g tronics and there are definitely some that are much smoother than others, but I have yet to drive one that is perfect. The best I’ve seen would be only be “acceptable” I agree with others that it is probably software related and maybe even has to do with the adaptations, but I doubt it’ll ever be perfect. Just my opinion based off what I’m told. I do hope what I’ve been told is wrong and that there is an actual fix, but based off my experience I lost hope.
#92
As you will see here, some have this problem, some don't.
Weird...
HotRodW (05-08-2023)
#93
GLE downshifting
#94
2021 GLE450
Perhaps the problem is similar across the board, however, some drivers are much more sensitive to the abrupt downshifts. My 2021 GLE does downshift in a manner that is not expected from a luxury vehicle. I do keep it in ECO mode to reduce the harshness of the downshift. If I forget to put it in ECO mode, I am abruptly reminded. Like many issues MB lets them linger from model year to model year , for example, on another model MB I own it has squeaky brakes on a 2018 I owned to the exact 2022 I currently own. Perhaps this is not just an issue with MB. If I really wanted the best fit and finish, reliability, and customer service I would buy a Lexus, too boring though.
djgiovanni (05-04-2023)
#95
I had the harsh shifting no matter the mode on my previous MY22 GLE. The GLC I was loaned at the time with the same 9G-Tronic gearbox was as smooth as water. So is my current GLE. definitely not a matter of some owners being more sensitive to the shifting behavior than others.
HotRodW (05-04-2023)
#96
Received 1,030 Likes
2024 GMC Canyon Denali..... 2018 Audi SQ5
2020 GLE 15k, 2021 GLE 53 17k, never a harsh shift-ever. I had a GMC truck with an 8 speed that occasionally had a harsh downshift when it decided to skip a gear downshifting. It’s hard to believe that one can’t recognize erratic behavior of any drive train component, but….
I doubt it’s a design flaw but more likely an internal valve. At least one member posted having a pressure valve replaced that resolved harsh shifting…as I recall it was a couple of years ago. How many Dealers have the capability to diagnose/repair transmission issues? Can get approval to repair? The probability is that the Dealer or Mercedes don’t want to tackle a tranny that isn’t broken.
#97
QUOTE=TonyF61;8770047]Nice MPG! Would you please elaborate on "full hybrid mode". I tried using ECO on highway, but didn't do much as I utilize cruise control, so wasn't worth the effort. Then, for me, local driving was constantly kicking in the engine as it was all stop and go driving.[/QUOTE]
Full hybrid mode; set dynamic drive to ECO. Watch tachometer as rpm’s drop to zero (auto start must be engaged; vehicle maintains a near constant speed on level or slight downhill grade even without cruise control engaged. I only recently discovered this after 2 years of vehicle ownership. Anyone else experience this ??
TonyF61 (05-09-2023)
#98
2021 GLE450
#99
Received 3,948 Likes
2017 GLE350 4MATIC
delete
#100
Poor Down Shifting
I went into Mercedes this week and had them address a recall on my transmission control module (NHTSA Recall IS 24V118). Can report the reprograming the transmission control module has resolved my poor down shifting issues. I suggest if you are still having problems, call Mercedes and see if you can qualifies for the upgrade/reprograming.
The following 2 users liked this post by randsny:
cupecoy (04-08-2024),
djgiovanni (04-05-2024)
