HUD Display Issue
But a week ago, the battery status/signal strength display is gone for most of the time (pic2). The weird thing is, for sometime, this will come back but for most of the time, it's gone. I haven't changed any settings.
The cellphone battery status and signal strength is always displayed on the MBUX main screen, though, like, all the time. (pic3)
Tried to use different phones to connect, including both iphone and android phones, same issue.
Any idea if this is some setting I should change or should I set up a service appointment with the the MB technician to have them take a look? thanks!
pic1
pic2
pic3
https://mbworld.org/forums/gle-class...ml#post8472163
They always blame it on poor wireless signal. AT&T, T-Mobile and Verizon has 100% signal but the car can't communicate. My remote start works only when i start it at home driveway. Never worked outside..
Did you try contact support & dealership? I have ticker opened 2 months ago. No response so far.
The pic that shows your phone battery charge was also showing a compass, the second photo without is showing distance to your destination. There are 3-4 different Left HUD portal menu settings, and each one turns off functions to declutter the HUD. On the left side of the steering wheel, hit the home button, then swipe up on the left steering wheel touch pad to get access to the HUD menu. Swipe left to get to the left HUD portal menu settings, then swipe up or down to select different left HUD portal settings. If you do this with your phone connected via USB, I believe you will find the setting that will shows your phone info as in your first pic. Also, make sure you are set to your profile before changing anything.
I'm guessing you inadvertently changed the left HUD portal setting, or perhaps a software update did it. It's happened to me.
- the car stayed with the dealership for one day and they told me today an update to the HUD software was made, BUT it still doesnt display the cellphone signal/battery status, They have no idea at all. So, the car was JUST returned to me…sigh. Since it’s not a major issue, i will just have to live with it.
Any suggestion would be appreciated.
- the remote start issue was fixed by the mercedes me tech team. Now it works every single time.This takes almost two weeks.
Have you fiddled with the heads up display and chosen the correct display choice for the left pane of HUD?
Then when you're on the above screen that lets you adjust vertical position (up/down) and brightness (left/right), it's not very clear that you can also click the thumbpad one more time to get the next settings screen:
