Screw size?
Screw size?
I'm trying to replace my license plate screws but can't find the right size. I got a CA custom plate which is black but the screw I have now is a huge silver one so I'd like to replace it with a black screw. My OCD won't let me keep the silver ones. ![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
Anyone know the right size? Thanks in advance.
nextmilenium (01-25-2022)
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
You could take the screw to a hardware store. The hardware section usually has a board that you can insert the screw into to determine the thread type.
edited to reflect any hardware store
The following 2 users liked this post by EddieKBG:
nextmilenium (01-25-2022),
TexAg91 (01-25-2022)
Have you thought of something like this?
HILLMAN 59052 Black Hinged Screw Covers (1/4") - 10 Pieces https://www.amazon.com/dp/B00NUFOZ8U...42E3N3TXM0X6PH
Thanks everyone for your suggestions.
I wanted to serve two purposes by replacing the big silver screws (philips head) with smaller black ones (hex head?)..one is the aesthetics and the other is make it somewhat theft deterrent. It's rare but the license plates do get stolen.
Received 1,182 Likes
2020 GLE 450; 2023 BMW M2 Coupe
License plate screws
to answer your question the thread is M 6 x 1, the stock bolt is 10 mm
This link is what you want in stainless black oxide, button head with a cool female hex drive, 12 mm length. I suggest getting a longer one if you are going through a frame, the 12 should do it, or 16 mm if its a thick frame
https://www.mcmaster.com/97763A824/
The following 3 users liked this post by Sieveboy:
