Steering Wheel Noises
During the vehicle drop-off (25 Jan 22) to the dealer I allowed my service consultant to review videos that I had taken to capture the noises. Since the drop-off, I have not received any language of a duplication or diagnosis.
I've only been provided with a video of the multi-point inspection and a text request from my sales consultant for the videos.
Any members having any identical issues - please provide any helpful feedback. I have also attached the videos herein.
The dealer had to replace the whole thing. The hard plastic assembly rubs against the faux metal finish piece at the bottom of the steering (very audible when you press that part between your fingers). Mine used to squeak when holding the wheels with 2 hands, driving around town. They also found a loose airbag or horn connector rubbing against the column inside.
My steering also exhibited very pronounced/sharp plastic casting edges around the bottom (inside the ‘U’ at the bottom where it meets the leather). The new one had less of those, the casting looked more precise.
Talk about quality at that price point. Talk to your SA and have them replace it, it’s not normal at all.
I'm merely taking notes - my car was not even looked at yesterday (Monday) either. I get the standard alerts from Mercedes me when the car is on, unlocked, etc. I will use Mercedes me as proof to show that they haven't been trying to diagnose my car.
I'll give them until noon today before I heighten this to the Service Mgr and the GM.
They changed the bar with updatet bolts and the problem solved. But now, 2 weeks later, I have a creaking sound on my steering wheel.
I don't know what should I do with this POS,
My car is driven only 4000 km, yes, 4K
Gle 450, 2022
I’ve been to the dealer three times within the first four months of ownership. I’m saving up a laundry list of items for my first major service next year. I refuse to let this poorly designed, poorly built, no-quality-control POS inconvenience me anymore. I’m lucky that I have the high-end Burmester where I can drown out the cacophony of incompetence (and MB denial) clanking around my car.
I moved over to Audi / picked up a 2022 Audi S5 Sportback. As the GLE was a lease / the Audi dealer I picked up my new car from was in the same auto group as Mercedes so they took the GLE back to them. 3 days later it was sold - such a shock.
Gle 450, 2022
I'm reaching out to the community for insights on an ongoing issue with my GLE, similar to a problem previously discussed here. Despite efforts to fix it, including a dealership visit where they addressed a steering assembly fault from the factory, I'm still facing challenges.
Here's a brief overview:
- **Tapping Sound:** A noticeable tapping sound from the steering when driving for more than 30 minutes. The sound is similar to something moving a millimeter back and forth, especially noticeable when braking or going over bumps.
- **Steering Drift:** The car tends to drift to the right, accompanied by a slight play in the steering column towards the right side.
- **Previous Attempts at Resolution:** The dealership had earlier found a defect in the steering column, attempted a realignment, and re-fastened screws. They also performed a wheel alignment and replaced the front tires due to uneven wear, which I suspect was caused by the steering issue. However, these measures didn’t fully resolve the issue, and the steering doesn't feel as it did originally.
- **Current Situation:** The dealership was unable to reproduce the issue on their recent check, leaving me without a clear path forward.
Given these persistent issues, I'm seeking advice on potential causes or solutions from those who might have experienced something similar. Also, if anyone knows the best way to escalate this to Mercedes' customer service department for more technical assistance, I’d appreciate the guidance.
Thank you in advance for your help and insights.
Service advisors have the toughest job in the dealership. They are the first to arrive and the last to leave everyday. And after 10 to 12 hour days they have to deal with irate customers.
But their job is not to diagnose problems. It's to convey the owner's description to the technician.
The owner's job is to make sure that what the service advisors wrote on the ticket is an adequate description of their problem, so The technician can replicate the problem. Before you okay the work order.
If it's difficult to describe, then make sure to write your own description, that's included for the tech.
Maybe find a location near the dealership where the problem is easily replicated.
If an owner isn't certain that the SA wrote an accurate description of the problem, then that owner needs to insist that a technician, the service manager, or the SA drive the car so they can replicate it for the technician, in person.
Going to a different dealership and getting a fix is often just a matter of getting better at describing your problem.
Edit: I agree that some dealership service departments are awful. That would have to be the worst service advisor job ever, to deal with customers with a lousy shop behind me. Turnover ensues.
