Sudden Jerks while in idle (parked)
Old Feb 14, 2024 | 01:07 PM
wildta's Avatar
GLE 580
Originally Posted by tootallll
The Auto Start/Stop feature on my 2022 GLE 350 causes a jerk motion when it kicks on and off.
The pre-facelift 350s don't have the 48v ISG system to reduce this jerk motion.
Old Feb 16, 2024 | 01:02 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
Put the car in Eco driving mode and 90% of this is eliminated because the car starts in 2nd gear.
Old Feb 16, 2024 | 04:26 PM
stktyz33's Avatar
MY2024 GLE 450
Considering the fact that disabling start/stop is super easy, like the button is right next to ignition start button, changing driving mode seems like an overkill. Additionally, the car can prompt to restore driving mode and start/stop status on start too. So, there are options.
Old Jun 2, 2024 | 07:26 PM
Baseballgirl's Avatar
GLC coupe 2022
Originally Posted by Shumai
Hello, does anyone else have this issue where when you’re parked, there is a sudden jerk or it feels like someone bumped into you. I am worried, trying to see if this is a normal thing or do I need to take it to the dealer. Car only have 3k miles on it.
Were you able to get any definite answers? I bought a 2022 GLC Coupe earlier this year. Once I got it home I'd put it in park and it would make the same jumping/jerk sound like you described. Techs don't know and I'm waiting to get it in with a specialist. It's like the brakes are adjusting or trying to set. The noise/jolt is every time I put it in park, but it's inconsistent and comes from the front and back. Sometimes it's more aggressive than others and is very annoying, considering it does feel like someone is bumping the car. Once I put the emergency park on (or open driver door) the Park brake is set and the noise and jolting stops. Any suggestions would be very helpful!! Thanks!
Old Sep 29, 2024 | 11:07 PM
007ML500's Avatar
2005 SL500, 2022 GLS 450
Anyone have a dealer resolve this? I have the same issue with the brake creep noise while in park. I'm taking into the dealer tomorrow but I do not have high hopes they will do anything about it.
Old Sep 30, 2024 | 05:07 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
I hadn't noticed this before, but it seems that if you put the car in park it roughly holds the brake at whatever percent you were when you pressed the park button. when you turn off the car, it then releases the brakes and either lets the parking pawl stop the movement or engages the parking brake. This will certainly result in some movement of the vehicle after you have put it in park and turned the engine off.
Old Sep 30, 2024 | 05:20 PM
  #32
007ML500's Avatar
I had the same theory so I came to a stop with minimum pressure, at most 1 or 2 bar pressure, then shifted to park. I did not reproduce it. Maybe a larger sample size would show different results.
Old Oct 5, 2024 | 11:13 AM
  #33
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
For 2024 Mercedes integrated the ISG into the transmission vs it was a seperate unit prior years. My 2024 had a violent jerk sufficient to rock the vehicle when the engine started when parked at stoplight. Same thing occured when starting out from using "brake hold". A big issue for a $140k luxury vehicle. Cycling the stop start buton produced a milder jerk. My two prior v167's were silky smooth. The Service Manager said he couldn't fix it...some are worse than others. Traded the car and it took 6 months for the Dealer to sell it at a big loss from what they gave me.
Old Oct 5, 2024 | 12:12 PM
  #34
W205C43PFL's Avatar
Ya that sounds like ISG Gen 2, more on it here: https://mbworld.org/forums/s-class-w...ml#post8666682
Old Oct 5, 2024 | 12:36 PM
  #35
graffixnyc's Avatar
2024 GLE 450 4MATIC
My 2024 350 jerks if I'm sitting idle and then the parking brake automatically engages after sitting there for a while. My 2017 GLE 350 did the exact same thing.
Old Oct 5, 2024 | 03:48 PM
  #36
W205C43PFL's Avatar
sorry wrong thread please ignore.
Last edited by W205C43PFL; Oct 5, 2024 at 03:49 PM. Reason: sorry wrong thread please ignore.
Old Oct 6, 2024 | 02:44 PM
  #37
Benzman33's Avatar
2024 GLE 350
My 24 350 feels like it's still rolling in park sometimes but then it catches itself? It's strange.
Old Oct 10, 2024 | 11:17 AM
  #38
MissingLEX's Avatar
GLE 350
Yes, mine does this as well. Good to know its just a normal thing and not something else wrong with this vehicle.
Old Oct 10, 2024 | 03:56 PM
  #39
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
It does this in my 2024 GLC300 and my wife's new to her 2023 GLE350 if idling for 10 minutes. I think is an annoying feature to make sure you're awake and paying attention. Must be part of the 20 minute shutdown warning.
Old Oct 21, 2024 | 01:39 PM
  #40
roccosifredi's Avatar
GLE400 & S350
Hi, I need help? I bought my GLE400 diesel 2020 4 months ago, with 100,000 km, in excellent condition with full equipment, it's a great car, but I don't always have one problem, so the problem may not be there for a few days, then it is: when I stop at a traffic light, hold on the brake, the car itself suddenly gets a vibration, a shock, a jump, I don't know how to describe it, it even happened to me that my car itself turned off in the middle of the traffic lights from that jump. I took it to the dealer for inspection, they told me that the car has no problem, but I'm not sure about them, otherwise the start stop function doesn't work, I don't know why, that's how I bought it, if anyone faces the same problem, I'd be very grateful help. thank you
Old Oct 21, 2024 | 02:26 PM
  #41
mikapen's Avatar
Sometimes mine comes to a stop in 2nd gear, then goes to 1st after stop, with a bit of a thunk. I think it's more likely to happen after I have dawdled around for a while.
Is there a way you can display the gear you're in, on the instrument cluster, to verify what gears you may be in for troubleshooting?
Old Oct 21, 2024 | 02:29 PM
  #42
jkaetz's Avatar
Turn off auto stop/start first and then tell us what happens.
Old Oct 21, 2024 | 05:15 PM
  #43
GLE400 & S350
mikapen I have not noticed at what speed it stops, I will notice it and write to you
Old Oct 21, 2024 | 07:50 PM
  #44
mikapen's Avatar
I was speaking about a display that shows your gear, not your speed.
To see if it's still in second gear when you come to a stop, and then shifts to first while you're standing.
It may be a fishing expedition but isn't that what troubleshooting is?
Old Oct 21, 2024 | 08:23 PM
  #45
GLE400 & S350
video jump
this is how it looks for me, in the first video it is getting a jump, and in the second video, it is getting a jump and the car shuts off
File Type: avi
File Type: avi
Old Oct 21, 2024 | 10:31 PM
  #46
wildta's Avatar
GLE 580
You might elicit more responses if you upload these to YouTube because a lot of members, including myself, avoid downloading videos for fear of viruses.
Old Oct 22, 2024 | 08:57 AM
  #47
jkaetz's Avatar
As an IT professional of over 20 years with an interest in security, an infected video file is HIGHLY unlikely. There have only been a few vulnerabilities found in media players over the years and cyber criminals usually target much larger audiences than the members of a relatively small automotive forum.
Ok so that's a strait up stall and definitely should not happen. Take that sucker in to your service center with the video. I was going to say it sounds like this https://www.carscoops.com/2024/02/a-...glss-and-gles/ but that is going from 7th - > 6th gear and you're coming to a stop. Hard to tell but is auto stop/start turned off as well? I suppose it could be the fuel pump issue as well. Plug your VIN into the MB recall site and see if anything comes up. https://www.mbusa.com/en/recall
Old Oct 22, 2024 | 01:18 PM
  #48
mikapen's Avatar
Good advice. Plus it's a format that I can't open.
Maybe some are OK with unknown downloads, but you're right, many aren't.
Old Oct 22, 2024 | 03:36 PM
  #49
wildta's Avatar
GLE 580
l
Good to know. Thx.
