2021 GLE450 Oil Change at Independent
Seems like 9qts 0-20 or 5-30 synthetic is required and the Mercedes oil filter.
Please kindly see attached.
On top of that, at least in some parts of the country, Mercedes service is a total rip-off. My last A service on my W205 was like $380. It's an oil change and a bunch of inspections -- something I could probably DIY for $80. So, I'm giving Mercedes $300 every service "to keep my warranty in tact" which I'm really not doing, because it will be in tract anyway. If I do that for 4 services over the 4 year warranty period, that's an extra $1200. The dealers and now people on forums are instilling this fear that you have to get it done at the dealer or worry about your warranty. It's simply not true, and not legally true.
That said, I started my post with "somewhat" disagree, because in general I have been taking my car to the dealer (as evidence of my A service). I've usually had other things for them to work on at the same time (warranty work, new tires, etc) so I find it convenient to get it all done at the same time and I spend extra money for that convenience. I know I'm overpaying and I'm personally ok with that, but I don't blame anyone who wants to save money and NOT use the dealer. And if you want to save some money and not use the dealer, don't worry about the warranty. Do the work on time, save your receipts, and make sure you use the proper spec oil.
Stop putting words in our mouths like we are trying to scare someone.
Unless you don't do the required services, which you may not be able to do at home for $80.
You or your independent should go through the warranty book and check off every item that's due, and sign it.
You probably won't be able to do system scans and updates at home. Your Indy probably doesn't have a hundred thousand dollar machine to do that work, but maybe they do.
But I have $100,000 car and I'm actually going to take care of it. Brake fluid flush, filter changes, etc.
And since people buy cars sight unseen these days, and most dealers provide a Carfax on their used cars, showing regular dealer maintenance is an attractive resale feature. Individuals and Independentd don't normally enter their services in Carfax.
I figure it costs me $150 extra to have them do the work, and I consider it an investment in my relationship there, as well as future value.
That said, below is the "Service A" and "Service B" right from the Mecredes website. This stuff is simply and easy to do and doesn't require any $100,00 machine to do. It's very important note that there are required things not on here that come up - spark plugs at 50k, air filter(s), etc...
But the initial Service A's and B's are:With the first visit at approximately 10,000 miles or 1 years whichever comes first – and then approximately every 20,000 miles or 2 years after that
Service A includes:
- Mercedes-Benz motor oil replacement
- Oil filter replacement
- Fluid level checks and corrections
- Tire inflation check and correction
- Brake component inspection
- Reset maintenance counter
What is Service B?
With the first visit at approximately 20,000 miles or 1 year after the previous service - and then approximately every 20,000 miles or 2 years after that - Service B includes:- Mercedes-Benz motor oil replacement
- Cabin dust/combination filter replacement
- Brake fluid exchange
"If you aren't using a MB branded OEM filter and MB approved oil, MB can...and likely will....void the warranty on your engine if there is a failure."
You can see how this statement differs from what you said. It's not a scare tactic, it's the truth. Furthermore, as others have already stated, with a complete dealership service history, MB and/or the dealership are much more likely to offer assistance (called goodwill fyi) if you have problems after your warranty has expired. It's called "being a good customer." If you think the services are overpriced, you should either 1) Not be driving a Mercedes or 2) Buy the prepaid maintenance package from MB which is a really good deal for most people and their car's needs.
You pay indirectly for that through higher shop rates than an Independent, which doesn't have the overhead to amortize, because they only have basic equipment.
Or warranty work during the same visit.
Pros and cons.
Pros and cons.
Your full statement that YOU quoted above is absolutely not true. Not using an "MB branded OEM filter" does not void the warranty at all, unless the filter specifically failed and that failure was the reason for the engine failure (in which case using a major filter brand you will be covered anyway). You also wrote (quoting an entire sentence to not put words in anyone's mouth) "Is it worth voiding the warranty on your $35k+ engine?" , which of course using and independent shop as the OP asked does not do (providing done on time with the right specific fluids which are plentiful).
I apologize if my words of "scare tactic" got too many people up in arms. When I read an answer to a question about and Indy shop (and not a question if I should use it) with replies that say don't go there, you'll risk a warranty on a 35k engine, etc. It definitely reads to me like scare tactics. It is not fair that I interpreted YOUR intentions so I probably should not have done so but should have said it appears to me like that. That said, what you wrote has inaccuracies that should be noted.
This will be my last post in this thread. I use the dealer most of the time. I have my reasons and obviously many of the people in this thread do as well. That said, keeping the warranty in tact is not a reason to do so. The OP asked about and Indy shop resetting the maintenance notice and he was told by multiple posters who referenced keeping the warranty that he should use the dealer. That is not a valid reason to go to the dealer and is backed up by law.
Oh, and good luck getting FRAM to pay a $50,000+ invoice for a new engine with installation.
Further evidence of your ignorance....taken directly from MB's warranty booklet:
ITEMS WHICH ARE NOT COVERED:
A few posts earlier you said the engine was $35k+…now it’s $50k+…Mr exaggerator🥱
The language in Mercedes warranty disclaimer is pretty standard in the industry. In the US the Magnuson–Moss Warranty Act is the final determining legal standard for warranty claims. There are a lot of good points made in this thread and as always some misinformation that can be corrected without insults..
There is a similar thread on the Porsche Forum (Rennlist), there are actual people with even more expensive cars changing their own oil. A post questioning why DIY, but no arguing, Pontificating, name calling, etc.
The Specs for the materials were discussed with helpful information on what to use and why: Extractor vs oil pan drain; Porsche approved Oil Specs and how they vary; YouTube Video posted showing the process including removing a brace. The members are much more courteous towards each other and the results more meaningful.
In addition, your constant cheerleading of the troubled one-sixty-lemon platform diminishes your credibility every time you force yourself to post a response.Porsche's are for weiners and nerds with overdriven egos. They've looked the same for 40+ years and nobody can tell the difference (or cares to) between a $200k or a $50k 911, because after all, they're just cars. Rennlist is the internet version of a circle jerk.
In addition, your constant cheerleading of the troubled one-sixty-lemon platform diminishes your credibility every time you force yourself to post a response.Porsche's are for weiners and nerds. They've looked the same for 40+ years and nobody can tell the difference (or cares to) between a $200k or a $50k 911, because after all, they're just cars. Rennlist is the internet version of a circle jerk.
